Servo Posted August 26, 2013 Share Posted August 26, 2013 I'm thinking of getting a Sony FS100, which shoots to a Super 35mm sensor and takes E mount lenses, though you can get an adapter for EF and EF S lenses. Metabones has an EF to NEX speed boost/full frame adapter, which lets you use EF (full frame) lenses on it, and it gives an addition stop of light. What I'm wondering about is if adding this between the lenses (EF and then anamorphic) could potentially create any issues for the image? Could it make focus difficult or create chromatic abberation? I realize vignetting is always a potential issue past a certain field of view, but I'm just wondering if the addition of however many millimeters the speed booster is can cause any problems. I wouldn't assume it would, but I haven't read anything specifically about using it on the FS100 and an anamorphic lens. Thanks. Link to comment Share on other sites More sharing options...
Julian Posted August 26, 2013 Share Posted August 26, 2013 Here is an example of a speed booster + anamorphic on a NEX. Should work the same for the FS100: http://www.eoshd.com/comments/topic/3066-speedbooster-effect-on-anamorphics/?p=39810 Link to comment Share on other sites More sharing options...
Servo Posted August 26, 2013 Author Share Posted August 26, 2013 That helps, thanks. For me I'm not looking so much for the speed boost but for the wider field of view for a short film. I didn't realize that vignetting would come into effect in the opposite manner that I thought-I assumed it would be more of an issue the longer the lens. I guess I'll always be able to take off that speed booster if it becomes a problem. That squirrel seems a little stuff. Link to comment Share on other sites More sharing options...
