Panasonic G6: MP4 vs AVCHD
pietz
hello everybody,
i recently got my G6 and i have been loving it so far. i can only recommend every GH2 owner to get one as well, since you can sell your used GH2 at a price, for which you can almost get a new G6. but thats a different topic.
Andrew has been talking about little to no differences in using MP4 instead of AVCHD with the new G6 and i would like to hear your thoughts on this. i used Media Info to look inside what these two file types bring to the table and would like to share it with you (i'm referring to the european model at 25fps):
What I dont understand to this very day is the naming of both recording options. AVCHD is the codec used to compress the file, whereas MP4 is the container file in which everything it put together. to me these are completely different things and not opposing options, since you can put a AVCHD coded video in an MP4 container.
when i open sample files in media info i can see that both files use the AVC codec. There are only 2 technical differences with these. the first one being that the MP4 option records at 20Mb/s whereas AVCHD goes up to 24Mb/s. thats a 20% increase which should bring little improvements.
The second difference is that MP4 uses the "Baseline" profile where AVCHD uses the "High" profile. the High profile enables something called CABAC, which in short compresses files better than than the CAVLC option used in the MP4 preset. you could say that MP4 uses H.263 whereas AVCHD uses H.264. H.264 is known to be 20-40% more efficient than H.263 (XviD, DivX).
so all in all there should be a visual difference between the two recording options, but until now, i havent been able to spot them. this also means one thing if im not completely mistaken:
if there is little to no difference using a 20% higher bitrate at 20-40% higher efficiency, i dont think there is a reason to hack the camera for even higher bitrates. the only reason to look into that, would be for All-I-Frame encoding, which i personally dont see the point of if you have a fast workstation.
Any thoughts?
  • 2 months later...
midloch
it looks superb very filmic ,
the G6 is a very filmic looking camera ,
its AVCHD files are great and very very detailed , better than my hacked GH2
you can make any camera look like video if you stick it on deep focus with a wide lens
its all about how you use the camera its not the AVCHD files as they are great
midloch
Yeah Andy, if only you could shoot this well! ;)  Seriously, a very watchable short, don't know why.  Looks like midloch has a girl, a dog and a g6.  He's living!
On the AVCHD, as nigelbb pointed out, AVCHD is saved in a the bluray file structure, something like that.  MP4 is really for people who want to email a clip, or shoot something that will appear in their DCIM folder.
FD lenses on my G6 are great
best one is the Canon FD 24-35mm L series f3.5
it is a very very sharp lens aspheric elements and is very cinematic
50mm f1.8 , 24mm f2.8 , 35mm f2.8 are all great lenses
The 35-105 f3.5 zoom is very usefull as is the 28-85mm f4 zoom
Would you mind share some clips shot with these lenses?
I can recommend Olympus OM 28/2.8 and 50/1.8
Any other recommendation for some other lenses? thx
The best lens I have ever bought was $30.  The Fujian c-mount TV lens.  So you need a c-mount adapter.  I shot many of these photos with that lens on my EOS-M last week.(all photos with blurry background).
It has a 1.7 f-stop, which means you get thousand-buck blur for pennies.  On the downside, few markings on lens, no electronics, and the image is distorted at higher f-stops.
http://www.flickr.com/photos/maxotics/sets/72157637618422775/
Thank you...the images look good
Guest
Reply to this topic...
  Only 75 emoji are allowed.
