toggen Posted March 12, 2012 Share Posted March 12, 2012 Hello! Have searched like crazy to find this one: ST GH2 Pistol Grip mentioned by Andrew in the GH2 Guide... nothing. Hey Andrew! :P Tips for an good alternative will make my day! Nothing on ebay-at least not with trigger build in. (PM me i you´re selling this stuff,ok?) Thanks , T Link to comment Share on other sites More sharing options...
ronjbase Posted March 13, 2012 Share Posted March 13, 2012 Here you go, the only problem I have with this grip it uses the same plug and the external mic input [url=http://www.ebay.com/itm/Video-Hand-ST-Grip-Kit-for-Panasonic-GH2-GH1-GF2-GF1-G1-/120713829034?pt=US_Camera_Battery_Grips&hash=item1c1b1adaaa]http://www.ebay.com/itm/Video-Hand-ST-Grip-Kit-for-Panasonic-GH2-GH1-GF2-GF1-G1-/120713829034?pt=US_Camera_Battery_Grips&hash=item1c1b1adaaa[/url] Link to comment Share on other sites More sharing options...
mopixels Posted March 13, 2012 Share Posted March 13, 2012 I bought one of these for $20. No battery capabilities, but it's great for camera handling. [url=http://photographyandcinema.com/products]http://photographyandcinema.com/products[/url] Link to comment Share on other sites More sharing options...
toggen Posted March 13, 2012 Author Share Posted March 13, 2012 Thanks a lot,folks! Saved me days of bloody surfing... :D T Link to comment Share on other sites More sharing options...
ronjbase Posted March 14, 2012 Share Posted March 14, 2012 @mopixels, me too, it's the handle on my rig.... Link to comment Share on other sites More sharing options...
toggen Posted March 14, 2012 Author Share Posted March 14, 2012 [quote author=mopixels link=topic=394.msg2504#msg2504 date=1331657866] I bought one of these for $20. No battery capabilities, but it's great for camera handling. [url=http://photographyandcinema.com/products]http://photographyandcinema.com/products[/url] [/quote] On it´s way now. 140$+ shipping to norway,rather expensive for Chinese stuff, i think. Is there a way around that mic-problem... a "splitter cable" or something?! will degrade sound-quality, maybe? Thanks,T Link to comment Share on other sites More sharing options...
Axel Posted March 14, 2012 Share Posted March 14, 2012 Hi Folks, this is my first posting in this forum. I have been reading occasionally on specific topics though and bought Andrews E-Book. The grips linked above are nice, but mine (see avatar and attachment) is better, and self-built. It consists of a quick-release-unit by Kaiser on a aluminium bar coated with a gel-filled bicycle-grip. Link to comment Share on other sites More sharing options...
Administrators Andrew Reid Posted March 14, 2012 Administrators Share Posted March 14, 2012 Axel, very nice indeed! Is it available? Link to comment Share on other sites More sharing options...
Axel Posted March 14, 2012 Share Posted March 14, 2012 Thank you, I was fishing for compliments. It's DIY. The rubber eyepad is from an old Super 8 camera. Your book was really helpful and inspring. So I'm glad for the oppurtinty to return the compliment. Link to comment Share on other sites More sharing options...
tvpglabs Posted March 22, 2012 Share Posted March 22, 2012 Axel, that looks awesome! Whats the chance of a guide on how you put it together, specifically mounting the arca swiss plate to the rod? Link to comment Share on other sites More sharing options...
Axel Posted March 23, 2012 Share Posted March 23, 2012 [quote author=tvpglabs link=topic=394.msg2825#msg2825 date=1332460253] Axel, that looks awesome! Whats the chance of a guide on how you put it together, specifically mounting the arca swiss plate to the rod? [/quote] It is ridiculously simple. I needed the quick release plate, because I have the same unit on a monopod, an Ace tripod, a shoulder rig and a mini stabilizer. You can take every system. I chose this, because it's cheap, only slightly more expensive than the most simple Cullmann (but smaller and made of metal, not plastic, the Cullmann release plate fits into this, so you cant use both systems). I decided against the more robust Manfrotto, because it is too heavy, and with the little Lumix, you don't need [i]heavy duty[/i]. I sawed a small aluminium plate (4mm, some old junk), to fit under the Kaiser unit and drilled four holes corresponding to the holes at the bottom of the unit. From the square sticks out a 3 cm long, 1 cm wide "tongue", which I bent in a vice in a ~ 40° angle. Under this part is screwed a 6,5 cm long massive aluminium bar with 20 mm diameter. The M6 screw thread and the flattened top happened to be ready to use :D (never chuck away any aluminium parts, best material there is). To reduce weight, I hollowed the bar finally with a 10mm driller, grip weighs 170 g. I painted the square black with permanent marker, in case the image confuses you. Link to comment Share on other sites More sharing options...
