AIVASCOPE 1.5x anamorphic lens, 2nd hands-on on GH4
Sebastien Farges
AIVASCOPE 1.5x anamorphic lens, 2nd hands-on GH4
after this two tests :
vimeo.com/341289409
vimeo.com/342429735
this is my third film test with the new Aivascope 1.5x anamorphic lens on my Panasonic GH4.
It’s a very sharp lens working great with some of my primes. It’s a single focus lens (you do the focus on it and let the prime on infinity)
In this 3rd movie you will see different shots done with (aperture wide open) :
GH4 4K uhd (no CC) 24p + Aivascope 1.5x anamorphic lens
Primes : Pentax-m 40mm pancake f2.8 at f2.8
(most of the time) Pentax-m 40mm + 2x vintage Telemore95 II at f2.8
Sicor-XL MC 28mm f2.8 at f2.8 Despite the fact the Pentax-m 40mm is less wider than the others, I like the result with it. The TELEMORE95 II 2x lens converter (bought 3€ on a flea market) does missed sharpness to the 40mm from Pentax (and the Aivascope), and I loose maybe 2 stops with it.
I’ve used a Dorr variable ND lens, on the GH4 the picture mode is on « portrait » with slight ajustments.
I did no color corrections at all.
Thanks for watching.
Heres is the characteristics of the Aivascope 1.5x lens :
Designed for Full Frame systems. Recommended taking lenses for full frame (16:9 aspect ratio) from 50mm to 90mm Single focus From 80cm to infinity. Non rotating front element. Focus ring rotate 190 degrees. Lens mounting clamp 52mm Filter size 82mm Weight 700 gr. Integrated focus gear.
Price : 2 250,00 €
Aivascope facebook page : facebook.com/aivascope/
thanks to Aivascope, Hayley, Nina, and the people of Bordeau.
a Seb Farges Movie
music : ”Stranger-Peaks”
23rd june, 2019
