cooking anamorphic
enny
Also I think you will be better off with diopters because if you do close focus by moving the front glass closer to the rear glass you will change the squeeze factor. Probably it will be reduced from 2x to 1.5x or so. If you use diopter the front and rear part can be farther away from each other thus the squeeze remains around the original value.
