Nikkor Posted September 20, 2013 Share Posted September 20, 2013 I got one like these http://transferconvert.co.uk/cinemania/iscon4.jpg for a normal price a few weeks ago, but mine is a 75mm version. It's actually shorter than a sankor but heavier. It lacks the charisma of the sankor but it is sharp. Anyway, I've been using this with a diy clamp but I think its not that great, I want to rotate the thing as I've been using it for stills to get "medium format feeling" (it looks vintage because of the warping and CA) and I want to change between widescreen and portrait fast. Since I want to dump the clamp and since vignetting is not a problem at 85mm even having the thing rather far away from lens, I was thiking of just screwing it to the filter thread (it's not so havy) I measured the rear filter thread and it seems like 49mm, but the screw is inside, so I will need a male to male adapter. There are a lot 49mm to whatever size, so thats not a problem, but I need something to rotate the lens in order to adjust the orientation. I could remove the glass from a cheap pol filter, but a cheap filter has cheap materials so I wanted to know if someone knows a better way, some sort of rotating filter without glass whatever. Link to comment Share on other sites More sharing options...
tony wilson Posted September 21, 2013 Share Posted September 21, 2013 i made a custom clamp for that lens best adapter ever contact redstan.com Link to comment Share on other sites More sharing options...
Nikkor Posted September 22, 2013 Author Share Posted September 22, 2013 I like your clamps a lot, I have one for my sankor but I want to do try a different aproach with this lens. Link to comment Share on other sites More sharing options...
