Video jitter when panning with Canon 7D
Nicholas
Make sure that the image stabilization is turned OFF on your lens.
But I suspect more that it's a side effect of shooting at 24 frames per second. If an object takes less than about seven seconds to pass from one side of the screen to the other, then you are likely to experience motion judder when viewing on a 60hz monitor. It is one of the limitations of that frame rate.
If you really need smooth motion, you may find that 30 and 60 frames (especially 60 frames) per second are better for your purposes.
