UncleBobsPhotography Posted July 21, 2019 Share Posted July 21, 2019 Does anyone know of a charger for NP-F batteries where you can specify the cut-off limit? Either the voltage or %-wise. There is often considerable amount of time between each time I use my NP-F batteries, and the batteries stays much healthier if you only charge them to 80% or 90% instead of 100% of full charge. I am therefore in search for a charger where you can specify the cut-off, and preferably one which can also charge several batteries at the same time at a decent speed. Link to comment Share on other sites More sharing options...
Avenger 2.0 Posted July 21, 2019 Share Posted July 21, 2019 Bought one at HobbyKing in the past for my RC battery charging (where you can specify cut-off voltage) and modified it with NP-F battery plate to do this. UncleBobsPhotography 1 Link to comment Share on other sites More sharing options...
UncleBobsPhotography Posted July 21, 2019 Author Share Posted July 21, 2019 1 hour ago, Avenger 2.0 said: Bought one at HobbyKing in the past for my RC battery charging (where you can specify cut-off voltage) and modified it with NP-F battery plate to do this. Thanks for the tip. I've got some DIY NP-F plates so all I need should be the charger and the right connector. Is there a specific RC-charger you would recommend? Link to comment Share on other sites More sharing options...
