Is it possible to get a full filmmaking kit into one case?
Oliver Daniel
I'm ambitiously attempting to put together a very accomplished filmmaking kit together that you can fit inside one of those hard, wheeled cases .
It's to facilitate a new service I'm working on.
The strategy is to be very mobile / portable but offering very high quality with a great range of tools.
Thought it would be fun to share with you guys.
Can it be done?
This is what I want to fit inside one hard case with wheels - and it needs to be as lightweight as possible ?
1.  Hybrid Mirrorless Camera
2. Two to three lenses covering wide to telephoto.
3. 5 inch monitor
4. Slider
5. Gimbal
6. Compact Tripod
7. Three lights with stands
8. Headphones
9. Shotgun Mic
10. Wireless Audio Transmitter / Receiver + Lav.
11. (if Mirrorless Camera has crap preamps) Audio Recorder.
11. Lens Filters (Variable ND etc)
12. SD cards
13. Cleaning Kit.
14. Batteries / Chargers.
How would you create yours? Can you get all of this in just one case?
15 minutes ago, BTM_Pix said:
This is a decent place to start.
They have an app to create foam inserts for all the various hard cases from Peli, SKB etc.
There is a limited preset library of lenses and cameras but you can photograph or use pack shots of your own gear as well.
https://mycasebuilder.eu
Awesome, thank you.
I'd start by taking all the gear and laying it out on a flat surface to see if that's possible.  Obviously a case works in 3D but you'd get a sense of how to lay it out, what might be a good starting point, and if it's hopeless to begin with.
I have padded inserts with velcro dividers that you can move around and face a similar battle each time I plan a holiday and have to work out how to fit everything in.
