pedrobrian Posted July 29, 2019 Share Posted July 29, 2019 Price: $329.00 Mamiya M645 Camera with 80mm f2.8 Lens and Prism Finder Great setup in Great Condition Mamiya M645 Camera: Camera body shows general wear from careful use, with scratches and enamel wear on edges and corners and the surface of the camera body. All the leatherette is taught and fully intact. Camera mirror is clean and free of dirt. Shutter is accurate. Film winding gears are strong and true. The Mamiya M645 is Mamiya's classic 6x4.5cm Film Camera. Numerous accessories give the opportunity to 'build' your camera into the machine you want it to be. From power winders, numerous viewfinders, and a wide range of lenses, the M645 offers great opportunities to customize your shooting experience. We have many of these Mamiya accessories available here in our store. If you don't see what you're looking for please let us know as we may have it in stock. Mamiya Sekor C 80mm f2.8 Lens: Lens is in excellent condition with some signs of use in the black housing. Glass is clean with only a few bits of pinpoint dust internally, typical of a lens this age. Otherwise there is no dirt, haze, oil, scratches, fungus, or marks of any kind. Aperture is snappy and responsive. The 80mm lens is equivalent to a 50mm on a 35mm camera and is the perfect prime lens for general photographic use and great in low light situations. Mamiya Non-Metered Prism Finder: Mamiya non-metered Prism finder shows moderate signs of wear from careful use, a few light marks and scratches in the enamel surface. There is a very light line that runs across the viewfinder glass. This is a common occurence on these finders and will have absolutely no impact on your images. Otherwise glass is sharp and clean. Finder provides a nice well-defined image even in bright sunlight. While this prism finder does not have a built-in light meter, it is 2019! Accurate metering apps are available on your smartphone or other device for under 3 bucks. There are even a couple great free ones. Overall Functionality: All functions work perfectly. Overall Appearance: Camera, Lens and Finder look very nice all around. Some wear in the black enamel on edges and rear of camera. Viewfinder shows a very light line that runs across the viewer internally. This will have absolutely no impact on your images. Camera, Lens and Finder made by Mamiya in Japan Sale includes: Mamiya M645 Camera Mamiya Sekor C 80mm f2.8 Lens Mamiya Non-Metered Prism Finder Mamiya "Pop-up" Winder Knob Mamiya 120 Film Holder Fresh Battery Link to comment Share on other sites More sharing options...
