GH3 low light hack?
paulraymaekers
  • 2 months later...
we dive closed circuit rebreathers, so 5 hours is no problem at all
not that we stay 5 hours all the time, but 2-3 hours is very normal
wow!
i would still use 5D3 with external bettery, not necessarily raw, but i just can't name any camera that does better than 5D3 in low light,
  • 2 weeks later...
There are no hacks for the GH3 at all. If you want to stick with the GH3 your best option is to buy a Metabones Speed Booster and fast Nikkor prime (e.g. 50mm 1.2 AI-s).
The Lumix GM1 and GX7 have much better low light performance than the GH3 and you can of course use your MFT lenses with them.
Otherwise, the Nikon D5300 is probably the best low light camera for video. Better dynamic range than 5D3 (non-raw). I believe the cheaper D3300 has the same tech as the D5300 so should perform the same.
