Dan Wake Posted August 8, 2019 Share Posted August 8, 2019 Hi, which cameras give us the simultaneous recording of proxy clips? And are those clips useful to smooth the edit workflow for people who use proxy to edit large files as raw format for example? Or do you need to manually create proxy files anyway when you have to start editing? Thx Link to comment Share on other sites More sharing options...
leslie Posted August 8, 2019 Share Posted August 8, 2019 as far as i'm aware your editor has to generate them. i know resolve can generate proxies, i have seen it in a menu somewhere. Pretty sure my p4k cant and i'm pretty sure i have played with most of the settings available. Personally i think that would have to be some type of gun camera to record two separate video streams at once but maybe some one out there can prove me wrong. It wouldn't be the first time . i know stills camera can take a raw and jpg at the same time. but i think video with its 24 frames per second is a different kettle of fish compared to stills Link to comment Share on other sites More sharing options...
Super Members Mattias Burling Posted August 8, 2019 Super Members Share Posted August 8, 2019 The Sony RX100va does it in camera. Link to comment Share on other sites More sharing options...
leslie Posted August 8, 2019 Share Posted August 8, 2019 Just now, Mattias Burling said: The Sony RX100va does it in camera. well that proves i dont know too much lol. do you find it beneficial or include it in your work flow ? Link to comment Share on other sites More sharing options...
Super Members Mattias Burling Posted August 8, 2019 Super Members Share Posted August 8, 2019 Never tried it, just read about it. But given Sony's laggy compression I probably would use it. Link to comment Share on other sites More sharing options...
Anaconda_ Posted August 8, 2019 Share Posted August 8, 2019 JVCs LS300 can record 960x540 proxies, but I think it's only if you're main recording is HD. It appears that 4K & proxies wouldn't work, but I'd have to double check that with the camera in front of me later if you're interested. Link to comment Share on other sites More sharing options...
Dan Wake Posted August 8, 2019 Author Share Posted August 8, 2019 1 hour ago, leslie said: as far as i'm aware your editor has to generate them. i know resolve can generate proxies, i have seen it in a menu somewhere. Pretty sure my p4k cant and i'm pretty sure i have played with most of the settings available. Personally i think that would have to be some type of gun camera to record two separate video streams at once but maybe some one out there can prove me wrong. It wouldn't be the first time . i know stills camera can take a raw and jpg at the same time. but i think video with its 24 frames per second is a different kettle of fish compared to stills Read here https://www.manualslib.com/manual/994675/Canon-Eos-C300-Mark-Ii.html?page=111 Nobody here use camera proxy workflow instead than process all the footage to create proxy after shooting? Isn’t it a huge waste of time? Link to comment Share on other sites More sharing options...
Anaconda_ Posted August 8, 2019 Share Posted August 8, 2019 21 minutes ago, Dan Wake said: Nobody here use camera proxy workflow I often do, but with external recorders. For example, I frequently shoot 4k raw on P4k and 1080 ProResLT with a baked in LUT on a Video Assist or Ninja Star. It's a real time saver for my workflow. Link to comment Share on other sites More sharing options...
kye Posted August 8, 2019 Share Posted August 8, 2019 24 minutes ago, Dan Wake said: Read here https://www.manualslib.com/manual/994675/Canon-Eos-C300-Mark-Ii.html?page=111 Nobody here use camera proxy workflow instead than process all the footage to create proxy after shooting? Isn’t it a huge waste of time? I use proxies all the time. I create 720p Prores proxies from the 4K h264 or 6K h265 source footage, which allows me to fit the source media onto the SSD of my laptop and edit on my daily commute to work. The 720 Prores cuts like butter and doesn't kill the CPU and battery. I just wish Resolve had a nicer way to render them. Link to comment Share on other sites More sharing options...
Dan Wake Posted August 8, 2019 Author Share Posted August 8, 2019 Thx for reply. Which is it the best workflow for creating proxy after shooting footage today? Link to comment Share on other sites More sharing options...
KnightsFan Posted August 8, 2019 Share Posted August 8, 2019 I create proxies with ffmpeg. I wrote a simple script to batch files. If I use hardware encoding and decoding, converting 10 bit HEVC to 1 Mbps H.264 proxies takes just a few minutes per hour of footage. When editing, I manually swap proxies and online media in Resolve using the "Re conform from bins" option. Slow motion footage usually doesn't reconform properly, so I leave conform lock enabled for slow motion clips. Link to comment Share on other sites More sharing options...
Robert Collins Posted August 9, 2019 Share Posted August 9, 2019 On 8/8/2019 at 12:35 PM, Mattias Burling said: The Sony RX100va does it in camera. The Sony A73s can record proxies along with 4K in camera - however you lose facial recognition focusing... Link to comment Share on other sites More sharing options...
Super Members Mattias Burling Posted August 9, 2019 Super Members Share Posted August 9, 2019 At no loss then. Link to comment Share on other sites More sharing options...
fuzzynormal Posted August 10, 2019 Share Posted August 10, 2019 On 8/8/2019 at 7:29 AM, Dan Wake said: Read here https://www.manualslib.com/manual/994675/Canon-Eos-C300-Mark-Ii.html?page=111 Nobody here use camera proxy workflow instead than process all the footage to create proxy after shooting? Isn’t it a huge waste of time? I do proxy edits for everything in Premiere. Is it a waste of time? Not for me. I’ll ingest the footage and a day’s shoot will take about an hour to transcode into low-res proxies. Usually I do this in the evening. In the morning it’s ready to go. The proxy editing is very responsive too. Actual Source 4K footage is too laggy and slow. Editing that stuff is an exercise in frustration. Link to comment Share on other sites More sharing options...
Mmmbeats Posted August 12, 2019 Share Posted August 12, 2019 C200 is very much set up for RAW / Proxy workflow, right? Link to comment Share on other sites More sharing options...
