lucabutera Posted September 8, 2019 Share Posted September 8, 2019 On 8/20/2019 at 1:25 PM, Emanuel said: Well, once the installing process means to screw the magicbooster anyway, the process can always be reverted at any time, isn't it @lucabutera ? Expand On 8/20/2019 at 6:53 PM, docmoore said: I assume that reverting the process will still leave indication of tampering ... so probably worth waiting till the camera is 9 months old or so ... warranty almost gone anyway. Expand First of all, I apologize for the delay with which I reply but I am very busy and I will be so for a long time. The new Magicobooster for Pocket 6K is similar to that of Ursa Mini Pro, the internal support is replaced with a threaded one, the IR filter, unlike the Production Camera, Ursa 4K and Ursa 4.6K is installed inside in a support of black round aluminum and construction to be replaced, this means that Blackmagic has planned to replace the IR filter. The very positive thing is that the Magicbooster will be installed inside with a threaded body and it can be easily removed whenever you want. For the warranty, it will depend on the user's technical capacity. If you follow the instructions correctly and leave no signs of tampering, the warranty will not be invalidated, otherwise even without using the Magicbooster there may be cases of damage not covered by the warranty. In any case, the Magicbooster will not damage your camera. Thank you. Emanuel and docmoore 2 Link to comment Share on other sites More sharing options...
Emanuel Posted January 11, 2020 Share Posted January 11, 2020 heart0less 1 Link to comment Share on other sites More sharing options...
JordanWright Posted January 11, 2020 Share Posted January 11, 2020 Emanuel and Super8 2 Link to comment Share on other sites More sharing options...
Emanuel Posted March 6, 2020 Share Posted March 6, 2020 From usual suspects: https://***URL not allowed***/lucadapters-magicbooster-full-frame-speedbooster-for-the-bmpcc-6k/ https://***URL removed***/news/7844619364/speedbooster-launched-for-6k-blackmagic-pocket-cinema-camera-to-emulate-full-frame-sensor cam1982 1 Link to comment Share on other sites More sharing options...
