TrueIndigo Posted August 13, 2019 Share Posted August 13, 2019 Here is my cheap DIY viewfinder eye cushion. I sewed together two elasticated hair bungees. The first one clasps the EVF surround, and the second one comes in a little over the viewfinder and makes a more comfortable cushion than the firm rubber eyecup. These things come in many different colours, though I chose photographic black to suit the camera. They also come in different sizes/thicknesses. You may be able to see from the scale of the Panny G7 what size these are (they fit quite tightly on the viewfinder surround, which is the main thing). Also using these lower profile hair bungees means I can swing the articulated screen past and it doesn't come off. You could choose a more bulbous bungee which would make an even more comfortable cushion, but if you are opening and closing the screen a lot it would be inconvenient. JordanWright and kye 2 Link to comment Share on other sites More sharing options...
Mako Sports Posted August 13, 2019 Share Posted August 13, 2019 I just use the Bluestar eye cushions kye 1 Link to comment Share on other sites More sharing options...
