P6K accessories
Emanuel
If an extra piece of glass between the sensor and the lens - on that fits between the sensor and the lens connectors gives you a (close to) full frame look, why isn't that a standard? If BMD put that in the 6k by default, and marketed it as FF6k50p with 4K 35mm crop there would be a queue around the block for the camera.
  • 2 weeks later...
  • 2 weeks later...
Because there is not such thing as a free lunch and such compromises lead to image degradation, which, if you don't care about FF, may be an issue to you.
  • 3 months later...
  • 1 month later...
