88 EOSHD Unified patch, no SH 720p option
Bandido
Hi Andrew, I just installed your 88 unified patch and everything seen to work fine in 1080p/i. The problem is that REC MODE is grayed out on the menu and the only options I have for REC QUALITY are FSH and FH. Is there anything missing in the patch or is this an operator error? Thanks!
I just noticed that REC MODE is active only when there is nothing connected to the HDMI port on the camera. I can select SH and H but as soon I hook an HDMI cable to the camera, it rolls back to FSH and FH.  Maybe this is a documented limitation. I don't remember how it was before the v1.11 firmware and the PTool hack.  Also, according to StreamParser the Average Total Bitrate of my 720p/60 clip is 15,588,718bps or 15.59mbps. This is similar to the results posted by AZVideo.
