Diopter for Sankor 16 D
landulf
You will need an adapter to mount to the front of your Sankor as it has no thread. Check out Redstan, he may have something, or get some blue tack.
Proper achromats are very expensive they will reduce your minimum focus distance and more than likely improve your image. Not to sound rude but that maybe an overkill on your Sankor. Plus Sankors are pretty sharp anyway in my opinion.
Close up diopters are cheap, maybe play around with those and see what you think.
do what i did get step down ring and use hot glue from amazon its industrial strength super glue will bond metal to metal with no problems but be warned once it is on it stays on. and then you can screw your diopter that what i did for my big ass lens 95mm ring for 86mm diopters. oh and it was all like 10 dollars
