Stab Posted November 2, 2013 Share Posted November 2, 2013 Hi, I'm using a Panasonic GH3 and recently bought the 'new' Samyang primes. I got the 16mm, the 35mm and the 85mm. The 35mm and the 85mm work great on a el cheapo Fotga adapter from ebay. No problems there. But the 16mm is horribly soft in the corners. And with corners I mean everything but the center. After testing multiple copies, I found out today that it's the adapter causing this effect. When mounting it on a Novoflex adapter (€170) the image was fine, even wide open. The problem is that I think €170 is too much for an adapter, especially in these 'quiet' times when money is an object. Which adapter should I buy? I don't want no $10 Ebay adapters anymore. Also, I have tried a 'Kiwi' midrange adapter (€50) and it gave me the same problem on the 16mm. Also, it had a lot of play on both sides of the adapter. So, what about in-between brands like Kipon? Would that seal the deal? Or is high-end the only way to go here, as the 16mm turns out to be a 'picky' lens? What do you guys think? Link to comment Share on other sites More sharing options...
Stab Posted November 3, 2013 Author Share Posted November 3, 2013 Nobody? Link to comment Share on other sites More sharing options...
