Nikon z6 EF ibis
zerocool22
Hello,
A stupid question, I am looking into the Z6 but I dont have any nikon lenses, so I need to buy a EF adapter. Any adapter recommendations?
Also does the IBIS on the Z6 work with an EF adapter with my EF lenses? (about to go on a trip, where I want to travel as light as possible).
Thanks!
2 hours ago, BTM_Pix said:
You can use the TechArt Pro E to Z adapter and stack the Sigma MC11 on it to get AF and IS for EF lenses.
Check with @Andrew Reid but I think I recall him saying that IBIS is supported as well.
https://www.eoshd.com/2019/07/first-look-techart-tze-01-sony-e-to-nikon-z-mount-adpater/
hmm looking at 550 euro(the 2 adapters togheter) for an EF adapter then, thats a bit too rich for my blood Im afraid
  • Super Members
Buying the adapter direct from TechArt and the MC11 from Amazon UK, its about £390 (200+190) which is about €450 so you can shave the price a bit.
You can also either pick up a used MC11 or get a cheaper version like a Viltrox or Commlite to probably get that below €400.
Kipon's AF adapters usually for for around €300 so if its the same sort of price then the two adapter solution will be more expensive but one advantage is that you get access to E mount lenses as well as EF and the other advantage is it is available now whereas I haven't seen a release date for the Kipon as yet.
