Sharathc47 Posted September 15, 2019 Share Posted September 15, 2019 I was glad to hear about the 12g SDI raw output by blackmagic design! But I have some doubts can someone help me clear this!? 1. SDI and HDMI, data rates comparison and how much output it can give you in terms of bit depth (12bit, 14bit, 16bit.)? 2. Is it possible to provide SDI output directly from mirrorless cameras instead of any other additional modules? 3. It seems SDI is superior over HDMI cables in terms of a)robustness (locking mechanism) , b)distance of signal transmission and c)almost similar price of atomos HDMI cable! Why are SDI cables professional and HDMI cables consumer? why are camera manufacturers preferring HDMI cables??????? Link to comment Share on other sites More sharing options...
Mako Sports Posted September 15, 2019 Share Posted September 15, 2019 SDI - cables lock in, you can run the cables significantly longer (several hundred feet) HDMI - cables don't lock in place (micro and mini are even flimsier) max out at around 50 feet Its just like comparing XLR audio cables to 3.5mm mini jack cables. Once you experience the pro grade XLR connectors its hard to go back to shitty 3.5mm audio cables. - At least if your a working pro.. IronFilm 1 Link to comment Share on other sites More sharing options...
Video Hummus Posted September 15, 2019 Share Posted September 15, 2019 This Quora answer will probably help: https://www.quora.com/Why-did-HDMI-succeed-where-HD-SDI-didnt Basically, money and ease of development. Big surprise.... As far as data rates compared to the SDI-12G HDMI 1.4 is up to 10Gbps HDMI 2.0 is out to 18Gbps Sharathc47 1 Link to comment Share on other sites More sharing options...
