DaVinci Resolve 10 Lite.... help :)
Dan Wake
All that I know about this software is that it allow to edit RAW footage. For example can I edit the whole film with this software? I mean "doing everything" like in premiere? Adding transitions, cut, copy, paste pieces on the timeline? Adding audio tracks? I mean what I have on my PC installed now?  Can I tell that i's a free premiere alternative? Does it work with H.264?
I have a couple of candles preserved in my room somewhere for something special, is it the case to light them?  :)
Thanks a lot! :)
Resolve 10 has basic editing functionality in the edit tab - if you're doing basic in/out type edits I could see maybe using it to cut something for the sake of not having to go out to an NLE and back. But I think for most even somewhat complex jobs you'll probably still want to use Resolve in conjunction with a full NLE.
Blackmagic is clearly beefing up the editing abilities of Resolve, though.
thanks for help. :)
NLE is a common editing software? what the acronym is for?
I have a problem maybe. I have opened Resolve 10 to try it for the first time but I had no luck.
I try to click on the tiny triangle to find my video content, but if I click on the triangle nothing happens. It does not show me anything like if C: where empty. Can you help me with this please?
edit.
In addition I have another HDD drive (external drive), but it does not show me on the list as you can see in this picture.
ok, solved. :)
found here: http://forum.blackmagicdesign.com/viewtopic.php?f=18&t=2711
then restarted the software and it worked.
I see that I have some glitch, for example video thumbnails show ugly vertical black stripes. also on the timeline. any fix for that?
I also ask for a tip. I opened h.264 clip 1080p (shot wit EOS 550d). Audio and video have some playback problem. It's "slow" if you know what I mean (no fluid playback).
I believe the cause of this may be that the preview window that show the video is in HD. On premiere I can set the video quality but I cannot find the option here, do you know where is it please?
thanks!
edit.
