Germy1979 Posted November 13, 2013 Share Posted November 13, 2013 I don't know if anyone has tried this, but this was how i could get slow motion from my C100. I (for whatever reason), just found out that the sdi output on the bmcc 2.5 sends a 59.94i interlaced signal when you shoot 29.97, or 30fps internally. I won't be around my cam for a bit to test this, but I could select 59.94i on my Ninja 2 when I had my C100 and split the fields in post with a program like JES deinterlacer. Crazy pain in the ass of steps, but it worked and I was able to pull smooth 60p overcrank with it with better resolution than the C300's 720p over crank. If it works with the BMCC, then I'm glad i kept my Ninja! Anybody try this? EDIT: You'd need an SDI to HDMI converter for the Ninja 2. Just to clear that one up before someone ask. Something like the Samurai or the Samurai Blade wouldn't need one however. Quote Link to comment Share on other sites More sharing options...
hmcindie Posted November 15, 2013 Share Posted November 15, 2013 Difference is that the C100 actually does record 60 interlaced frames, the BMC doesn't. It only sends an interlaced signal but the frames are still progressive 30p inside it. Quote Link to comment Share on other sites More sharing options...
Germy1979 Posted November 15, 2013 Author Share Posted November 15, 2013 Yeah i actually tried this when I got home, all excited... fail. I figured this post just got lost in the mix so I didn't follow up, lol. Quote Link to comment Share on other sites More sharing options...
