leslie Posted October 14, 2019 Share Posted October 14, 2019 wow, whoever used that lens before had some serious intent about the lenses not falling apart, like caleb said its not really an issue if it is stuck at infinity focus, as a single focus solution will fix that. If its not at infinity focus you may have a problem. You may also have a problem if you wanted to use it dual focus till a single focus solution turned up. Depending how competent you are as a handyman, you could pull it apart. or get it serviced perhaps but that might cost near as much as you paid for it. Link to comment Share on other sites More sharing options...
ken Posted October 15, 2019 Share Posted October 15, 2019 On 10/13/2019 at 10:58 AM, PeterA said: Here's the lens and the metal indentations. Looks like this lens was modified somewhere. There are some little screws which can disassemble all parts. I also mods it as no lock(re-drilled holes to make it) . The rear big ring is not necessary. It was for adapting to around 71mm(70.65?) projector lens. Link to comment Share on other sites More sharing options...
PeterA Posted October 15, 2019 Share Posted October 15, 2019 Thank you all for your feedback. I really appreciate it. Link to comment Share on other sites More sharing options...
Rudolf Posted October 24, 2019 Share Posted October 24, 2019 On 9/27/2019 at 5:09 AM, ken said: I also like to mount this anamorphic lens and take photos vertically. So just looks as normal, not widescreen. ? 1. F1.8 2. F5.6 (to get good flare, need to use small aperture) Nice! Just tried it with ELMO II and Pana 35-100 (GH5 VLOG L). Interesting combo because autofocus sometimes helps double focus Link to comment Share on other sites More sharing options...
Dude_ger Posted October 25, 2019 Share Posted October 25, 2019 On 10/15/2019 at 3:18 AM, ken said: Looks like this lens was modified somewhere. There are some little screws which can disassemble all parts. I also mods it as no lock(re-drilled holes to make it) . The rear big ring is not necessary. It was for adapting to around 71mm(70.65?) projector lens. Dude, does the 62mm step up fit on the Isco´s threads?? Link to comment Share on other sites More sharing options...
ken Posted October 25, 2019 Share Posted October 25, 2019 1 hour ago, Dude_ger said: Dude, does the 62mm step up fit on the Isco´s threads?? Yes. Perfectly. Dude_ger 1 Link to comment Share on other sites More sharing options...
wei Posted December 26, 2019 Share Posted December 26, 2019 I own a red Isco 2x version. some say that it has barely no flares. But after several tests, I found that the flares really varies depending on what main lens you are using. for example, with a cctv 50mm toy lens and SLR rangefinder, I got a really amazing horizontal and rainbow flare. heart0less and mercer 2 Link to comment Share on other sites More sharing options...
