Can the Sony FS7 pair with the Ninja V (non-RAW)?
Mmmbeats
Quick question, probably not worthy of a thread, but I couldn't find a home for it.
I know that the Ninja V can't record RAW from the FS5, but can it record a 4K 10-bit signal at all from the camera?  Either via HDMI or the SDI adaptor.
Is there any 5-inch recorder that would enable 4K 10-bit?  I know that for RAW you would have to step up to the larger recorders.
Cheers.
FS7 can output 10-bit 4:2:2 via HDMI up to 4K30fps. I've tested it successfully with a Ninja V even though it isn't really necessary since FS7 records 10-bit 4:2:2 internally up to 4K60p.
  On 9/27/2019 at 1:02 PM, barefoot_dp said:
There's no 5" monitor that can record 10bit from the FS5. The FS5 only does 10bit via Raw/SDI; HDMI is limited to 8 bit.
Expand
The Ninja V with the SDI module should allow 10-bit recording from the FS5.
  On 9/28/2019 at 3:23 AM, thebrothersthre3 said:
Ah yeah you do need SDI, shogun Inferno will do 120fps 4k prores RAW
Expand
Yeah, but it's 7-inch.  This is the problem.  Those monitors (all of the compatible Atomos and Convergent Design products) are huge compared to the FS5 body and look like they will make handling a little awkward too.
sid-nate-shogun-setup-5-e1513708417994.j
Here's the camera with the Shogun Flame and the sun hood:
  On 9/29/2019 at 9:02 AM, Django said:
@Mmmbeats why is this thread titled FS7 when it's visibly about FS5?
Expand
Because I made a mistake with the title ?.  Though in my defence, you seem to be the only person (including myself up till now), who has spotted it.
I've been sizing up a bunch of cinema cameras for a possible future purchase (all the usual suspects), including the FS7, but, yes, this query was about the FS5.
  • 2 years later...
