Harrison Geraghty Posted November 19, 2013 Share Posted November 19, 2013 I'm finally updating my computer situation and have recently purchased the BMCC camera (along with the Bolex Anamorphot 8/19/1.5x anamorphic lens which I will add test videos to that section when I'm able) and want to shoot in 2.5k raw primarily for short films. I would like to know if this computer is capable of that, I appreciate this seems like a lazy question but I have spent time researching it but would like a fellow forum geek to affirm my decision. Thanks and sorry for being so cheeky. Link to comment Share on other sites More sharing options...
Andrew Doyle Posted November 22, 2013 Share Posted November 22, 2013 yes Link to comment Share on other sites More sharing options...
HurtinMinorKey Posted November 22, 2013 Share Posted November 22, 2013 Yes, easily. But your editing experience will might be a bit choppy if you try and edit directly off your HD. You should consider faster external storage using Thunderbolt. Harrison Geraghty 1 Link to comment Share on other sites More sharing options...
Caleb Rasak Posted December 9, 2013 Share Posted December 9, 2013 Dont upgrade your ram through apple you can save around $600. Its super easy to install yourself. Also get an ssd unless you have 3tb of applications. It not a good idea to be editing off your internal drive. Link to comment Share on other sites More sharing options...
Lung Posted December 10, 2013 Share Posted December 10, 2013 I plan to get the BMCC next month also. Since Harrison's question seems to have been answered and my own is related, I'd like to know about doing the same on the following computer. Or is it under spec'ed? I do plan to order more RAM (via OWC) and to work off of an external SSD, whether I get a newer computer or not. Hopefully no one minds. Thanks for any help. Link to comment Share on other sites More sharing options...
HurtinMinorKey Posted December 10, 2013 Share Posted December 10, 2013 I plan to get the BMCC next month also. Since Harrison's question seems to have been answered and my own is related, I'd like to know about doing the same on the following computer. Or is it under spec'ed? I do plan to order more RAM (via OWC) and to work off of an external SSD, whether I get a newer computer or not. Hopefully no one minds. Thanks for any help. The GTX 660M does not have enough vram to run resolve. You really need to get the 680MX in that version of the 2012 iMac. Link to comment Share on other sites More sharing options...
Lung Posted December 10, 2013 Share Posted December 10, 2013 I will likely look into that one or newer, as I'd like to run Resolve. Thanks for the info, HurtinMinorKey. On rethinking the above, I actually also have an older 2008 Mac Pro tower here that I hadn't considered. It has a default ATI 2600XT GPU. Any suggestions for GPU upgrades? I'm hoping that marrying the Mac Pro with a LED display or such would not only be the cheaper route, in my case, but would also allow me to repurpose it. Link to comment Share on other sites More sharing options...
HurtinMinorKey Posted December 11, 2013 Share Posted December 11, 2013 I will likely look into that one or newer, as I'd like to run Resolve. Thanks for the info, HurtinMinorKey. On rethinking the above, I actually also have an older 2008 Mac Pro tower here that I hadn't considered. It has a default ATI 2600XT GPU. Any suggestions for GPU upgrades? I'm hoping that marrying the Mac Pro with a LED display or such would not only be the cheaper route, in my case, but would also allow me to repurpose it. I think the 680 GTX will work with your old mac pro http://www.bhphotovideo.com/bnh/controller/home?O=&sku=970416&Q=&is=REG&A=details This is significantly more powerful than the 680MX mentioned above, but it's not cheap. Link to comment Share on other sites More sharing options...
Harrison Geraghty Posted January 8, 2014 Author Share Posted January 8, 2014 Thank you so much for responding, I was going to invest in one of these for editing purposes: http://www.rcblogic.co.uk/p-3241-g-tech-g-raid-7200rpm-thunderbolt.aspx?source=paidclick&gclid=CJW5tJ_97rsCFUnjwgod60gAQA Would this be a suitable external device for colour correction and editing? With this external device will I get real time playback and if not will it at least be relatively speedy? I intend to put the rushes I want to use on that drive, edit the finished film in 2.5k raw and then delete the rushes and keep using it for a project to project basis storing the finalized films onto cheaper g drives. Thanks again for your response. Link to comment Share on other sites More sharing options...
