Vision Posted September 29, 2019 Share Posted September 29, 2019 So where do i start i have some Hoyas Nd filters And i recently noticed on my old footages from GH5 that there was slight green tint Scenario: Day time sunny Settings 180deg shutter 60fps 10bit White balance set to 5600k Exposure using waveform Now how do peeps tackle this? i noticed you can tweak whitebalance in GH5 but i haven't got clue and i couldn't find anything that specified my issue i really hope i can find solution as am going on shoot with my S1 lumix THank you. Link to comment Share on other sites More sharing options...
thebrothersthre3 Posted September 29, 2019 Share Posted September 29, 2019 Use the custom white balance function against a grey card. UncleBobsPhotography, EthanAlexander and Vision 3 Link to comment Share on other sites More sharing options...
OliKMIA Posted September 29, 2019 Share Posted September 29, 2019 How strong is the ND? Past a certain point/ND strength, you may want to use an IR filter as well. Link to comment Share on other sites More sharing options...
Snowbro Posted September 29, 2019 Share Posted September 29, 2019 Lucky, you got that Arri look for free Link to comment Share on other sites More sharing options...
Grimor Posted September 29, 2019 Share Posted September 29, 2019 For 1 year I have compiled a set of tiffen nd 4x4 of 1,2, 3 and 4 stops. All second-hand and from different vendors. For a strange reason, the 3-stop one (0.9) has that green tint, which the rest of the set does not have. Has tiffen's quality control failed? Or can it be a fake copy? Link to comment Share on other sites More sharing options...
Vision Posted September 29, 2019 Author Share Posted September 29, 2019 4 hours ago, OliKMIA said: How strong is the ND? Past a certain point/ND strength, you may want to use an IR filter as well. Any recommendations on IR filter? Basically screw on ir filter and then nd on top? 5 hours ago, thebrothersthre3 said: Use the custom white balance function against a grey card. Need to get one like passport size maybe as i run and gun Link to comment Share on other sites More sharing options...
Vision Posted September 30, 2019 Author Share Posted September 30, 2019 5 hours ago, Snowbro said: Lucky, you got that Arri look for free More like Red?anyways i did some googling and thanks to all of you guys i found filter from Tiffen has anyone used them or any recommendations would be appreciated https://www.bhphotovideo.com/c/product/1394768-REG/tiffen_w82natnd15_82mm_natural_neutral_densitiy.html?selectedType=Size&Size=58mm&Density=5-Stop Link to comment Share on other sites More sharing options...
kye Posted September 30, 2019 Share Posted September 30, 2019 Do what you can in-camera and then remember you can tweak footage in post using Temperature (yellow/blue) and Tint (green/magenta) adjustments. Vision 1 Link to comment Share on other sites More sharing options...
newfoundmass Posted September 30, 2019 Share Posted September 30, 2019 2 hours ago, Vision said: Any recommendations on IR filter? Basically screw on ir filter and then nd on top? Need to get one like passport size maybe as i run and gun Lightdow 12 x 12 Inch (30 x 30 cm) White Balance 18% Gray Reference Reflector Grey Card with Carry Bag [Folded Version] https://smile.amazon.com/dp/B00HT9MA1W/ref=cm_sw_r_cp_apa_i_sjwKDbJFCK8A6 That's the one I have. It folds up into a tiny little bag. Vision 1 Link to comment Share on other sites More sharing options...
Snowbro Posted September 30, 2019 Share Posted September 30, 2019 53 minutes ago, Vision said: More like Red?anyways i did some googling and thanks to all of you guys i found filter from Tiffen has anyone used them or any recommendations would be appreciated https://www.bhphotovideo.com/c/product/1394768-REG/tiffen_w82natnd15_82mm_natural_neutral_densitiy.html?selectedType=Size&Size=58mm&Density=5-Stop I have always used Tiffen and haven't noticed a problem Link to comment Share on other sites More sharing options...
newfoundmass Posted September 30, 2019 Share Posted September 30, 2019 If you have the money get a nicer ND, but it's really not necessary. With a custom white balance and that $7.99 gray card I posted you'll be good to go. I'd just save the money! heart0less, Vision and Mako Sports 3 Link to comment Share on other sites More sharing options...
Adam Kuźniar Posted September 30, 2019 Share Posted September 30, 2019 TBH on the GH5 I just figured out what's the exact tint difference and then I put it in the camera and bam, problem gone. Link to comment Share on other sites More sharing options...
Vision Posted September 30, 2019 Author Share Posted September 30, 2019 1 hour ago, Adam Kuźniar said: TBH on the GH5 I just figured out what's the exact tint difference and then I put it in the camera and bam, problem gone. Hey Adam is that in wb settings u adjusted tint? Or am missing something Link to comment Share on other sites More sharing options...
Cinegain Posted September 30, 2019 Share Posted September 30, 2019 Vision and Adam Kuźniar 2 Link to comment Share on other sites More sharing options...
Vision Posted September 30, 2019 Author Share Posted September 30, 2019 24 minutes ago, Cinegain said: Yah i need to dig in to that more thank you Cinegain?? Link to comment Share on other sites More sharing options...
Adam Kuźniar Posted October 1, 2019 Share Posted October 1, 2019 16 hours ago, Vision said: Yah i need to dig in to that more thank you Cinegain?? Yep it's super useful. What I did is setup a scene, take a picture, put on the filter and then flip between image preview and shooting mode and try to match them more or less After that you just remember the values and it's fast to put them back on later Vision 1 Link to comment Share on other sites More sharing options...
