AZVideo Posted March 23, 2012 Share Posted March 23, 2012 I have been trying out the 88 EOSHD Unified patch and most everything seems to work as expected, but 720p 60fps is only recording at about 15Mbit instead of the documented 88Mbit. Am I doing something wrong or is this a bug in the patch? There is at least one other person posting simular issues. Can someone else test the 720p 60fps setting and see what bit rate you are getting? Thanks, David. Link to comment Share on other sites More sharing options...
Administrators Andrew Reid Posted March 23, 2012 Administrators Share Posted March 23, 2012 It is variable bitrate, the allocated amount depends on what you're shooting. Stop the lens down to F11, go wide angle, in good light with lots of movement and detail then test again. Link to comment Share on other sites More sharing options...
