Ronin S horizon level
zerocool22
Hello guys,
Small question is there a way to keep the ronin S at horizon level at all times? Even when holding the trigger and making turns the horizon drifts off slightly to the left or right. Balance test is excellent in all directions btw. So im guessing it should be some kind of setting, as when one is moving a single hand gymbal around surely it is normal to move it an awkward position making it drift. But surely there is an option to keep it horizon level? If so, how do I do it?
Thanks!
First, auto tune your motors, then set the joint angle as described in this thread:
forum.dji.com/thread-163729-1-1.html
Then...
1) With the app on your phone/device connected to the Ronin-S, go into the SMOOTHTRACK setting.
2) For Pan set Speed=High, Deadband=0, Sensitivity=100. Pushpan=Off
3) For Tilt set Speed=High, Deadband=0, Sensitivity=100. Pushpan=Off
4) For Roll set Smoothtrack and Pushpan = Off
This has fixed my Ronin
