shooter Posted November 19, 2019 Share Posted November 19, 2019 I wonder... because I dislike weak smartphones video codecs. What about if I edit on high quality ProRes? Link to comment Share on other sites More sharing options...
no_connection Posted November 19, 2019 Share Posted November 19, 2019 In theory it would only make it worse, however you could do quite a bit of post processing and AI stuff to it and then send that to a better codec for editing. As for just transcoding it would be up to the editing software if it's helped in any way by it or not. Link to comment Share on other sites More sharing options...
Evgeniy Posted November 19, 2019 Share Posted November 19, 2019 You're not going to gain any increases in quality. The only benefit would be to improve performance when editing prores vs h264 or similar. Mako Sports and Geoff CB 2 Link to comment Share on other sites More sharing options...
Mokara Posted November 19, 2019 Share Posted November 19, 2019 It will only make things worse because transcoding will result in loss of additional information. Transcoding should only be done to aid editing itself, if you don't need to you should not do it. Link to comment Share on other sites More sharing options...
EphraimP Posted November 19, 2019 Share Posted November 19, 2019 Is there a solution for lossless or virtually lossless transcoding? That's one of the things that frustrates me about video, coming from a stills background where I could shoot in RAW and edit in TIFF and export JPGs for final delivery. Working with log 4K 422 ProRes files is nice, but it's still like working in a JPG format if every time you export you lose info. Link to comment Share on other sites More sharing options...
KnightsFan Posted November 19, 2019 Share Posted November 19, 2019 20 minutes ago, EphraimP said: Is there a solution for lossless or virtually lossless transcoding? That's one of the things that frustrates me about video, coming from a stills background where I could shoot in RAW and edit in TIFF and export JPGs for final delivery. Working with log 4K 422 ProRes files is nice, but it's still like working in a JPG format if every time you export you lose info. There are lossless formats, including TIFF image sequences. The downside is that file sizes will be astronomical. What type of intermediates are you using, and can you use a proxy workflow instead? Using proxies instead of uncompressed intermediates will have the same fidelity and be a lot less taxing on hard drives. Link to comment Share on other sites More sharing options...
EphraimP Posted November 19, 2019 Share Posted November 19, 2019 8 minutes ago, KnightsFan said: There are lossless formats, including TIFF image sequences. The downside is that file sizes will be astronomical. What type of intermediates are you using, and can you use a proxy workflow instead? Using proxies instead of uncompressed intermediates will have the same fidelity and be a lot less taxing on hard drives. I'm using ProRes from my Ninja V as much as possible. And I've used proxies, so I get how they help speed up a workflow and take pressure off of my processor. I'm more concerned about intermediate deliverables to a third party, such as cutting the best take from a multiple take sequence to send to a client, or storage. If I shoot a long sequence, such as an interview, and decided that say, 75 percent is garbage and 10-25 percent is perfect, it would be nice to cut the crap out and be able to transcode the good stuff for future use/long term storage without losing quality. Does that make sense? Link to comment Share on other sites More sharing options...
KnightsFan Posted November 20, 2019 Share Posted November 20, 2019 17 minutes ago, EphraimP said: I'm using ProRes from my Ninja V as much as possible. And I've used proxies, so I get how they help speed up a workflow and take pressure off of my processor. I'm more concerned about intermediate deliverables to a third party, such as cutting the best take from a multiple take sequence to send to a client, or storage. If I shoot a long sequence, such as an interview, and decided that say, 75 percent is garbage and 10-25 percent is perfect, it would be nice to cut the crap out and be able to transcode the good stuff for future use/long term storage without losing quality. Does that make sense? Yes, that makes perfect sense. With most codecs you can losslessly trim a portion out. It can be done with ffmpeg, I've done it for archiving GoPro footage from long events. I don't know whether any mainstream editing software can do this--there is an option to "only re-encode when necessary" in Resolve but I haven't tried it. On All-I codecs such as ProRes, this should be possible with cuts on any frame, but with intra-frame codecs, you would begin your trim on a I frame. Unlike an uncompressed format like your TIFFs, cutting out a portion of a compressed codec won't be lossless across edits. For example, you can't color correct it and maintain your complete fidelity with this method. On the other side, most codecs will not show any degradation over a single re-encoding. Avoid it when possible, but it's usually not the end of the world if you're not doing it a few times. EphraimP 1 Link to comment Share on other sites More sharing options...
EphraimP Posted November 20, 2019 Share Posted November 20, 2019 4 minutes ago, KnightsFan said: Yes, that makes perfect sense. With most codecs you can losslessly trim a portion out. It can be done with ffmpeg, I've done it for archiving GoPro footage from long events. I don't know whether any mainstream editing software can do this--there is an option to "only re-encode when necessary" in Resolve but I haven't tried it. On All-I codecs such as ProRes, this should be possible with cuts on any frame, but with intra-frame codecs, you would begin your trim on a I frame. Unlike an uncompressed format like your TIFFs, cutting out a portion of a compressed codec won't be lossless across edits. For example, you can't color correct it and maintain your complete fidelity with this method. On the other side, most codecs will not show any degradation over a single re-encoding. Avoid it when possible, but it's usually not the end of the world if you're not doing it a few times. Thanks, that's super helpful to know. I've not messed with ffmpeg yet. And sound like another in a million reasons why I need to buckle down learn Resolve. Link to comment Share on other sites More sharing options...
fuzzynormal Posted November 20, 2019 Share Posted November 20, 2019 Once a bucket is full, you can't add more water to it. Link to comment Share on other sites More sharing options...
shooter Posted November 20, 2019 Author Share Posted November 20, 2019 I'm afraid to be misunderstood. Let's take on this example of the bucket. Imagine to replace it for a larger bucket (editing/grading codec). Same portion of water (camera codec). That's my point. Doesn't a stronger intermediate codec help for grading? Link to comment Share on other sites More sharing options...
kye Posted November 20, 2019 Share Posted November 20, 2019 6 hours ago, KnightsFan said: Yes, that makes perfect sense. With most codecs you can losslessly trim a portion out. It can be done with ffmpeg, I've done it for archiving GoPro footage from long events. I don't know whether any mainstream editing software can do this--there is an option to "only re-encode when necessary" in Resolve but I haven't tried it. On All-I codecs such as ProRes, this should be possible with cuts on any frame, but with intra-frame codecs, you would begin your trim on a I frame. Unlike an uncompressed format like your TIFFs, cutting out a portion of a compressed codec won't be lossless across edits. For example, you can't color correct it and maintain your complete fidelity with this method. On the other side, most codecs will not show any degradation over a single re-encoding. Avoid it when possible, but it's usually not the end of the world if you're not doing it a few times. This kind of thing can be very useful if you have long takes with a high shooting ratio.. one thing is for sports if you're recording in slow-motion and waiting for something cool to happen - you can end up with minutes of footage that are completely useless. For the purposes of editing I tend to wait until the moment has definitely ended and then stop the take and start a new one. Then in editing I don't have to scan a long clip (120p takes forever to watch) as I can just look at the end of the clip and see if something good happened. I haven't hit this issue, but if file sizes are too large (maybe with the P4K / P6K this would be more relevant) then you can split the source clip into multiple pieces and delete the minutes of unused footage. Hard-drive space might be cheap these days, but recording RAW can add up and it might be worthwhile to trim long clips. P6K 6K Blackmagic RAW 3:1 is 323 MB/s, which is ~1TB per hour. 6TB internal HDDs are $225, and archival should be on redundant HDDs, which means that the 323MB/s is about $75p/h, or ~$1/minute. So, if your hourly rate is $75p/h is less than the space you can free up by splitting and deleting un-needed source footage then you can come out ahead. Link to comment Share on other sites More sharing options...
kaylee Posted November 20, 2019 Share Posted November 20, 2019 1 hour ago, shooter said: Doesn't a stronger intermediate codec help for grading? I posed the same question recently, and after my own investigation which involved actually doing this with the short im working on, heres my position on this... the answer is: yes and no YES, transcoding to a higher resolution, higher bitrate, etc, format could benefit your work in post IF youre • doing vfx • sharpening the footage *doing other stuff like that, theres lots of benefits BUT! NO, • you wont get some magic out of this process to get more out of your grade per se. what youre doing with color and exposure isnt gonna have more latitude just bc you make your crappy phone footage prores 444. u kno? thats my take on it, correct me if im wrong guize~! shooter and mercer 2 Link to comment Share on other sites More sharing options...
Mokara Posted November 20, 2019 Share Posted November 20, 2019 4 hours ago, shooter said: I'm afraid to be misunderstood. Let's take on this example of the bucket. Imagine to replace it for a larger bucket (editing/grading codec). Same portion of water (camera codec). That's my point. Doesn't a stronger intermediate codec help for grading? You are substituting one method of encoding for another. The second encoding is going to discard information it deems unnecessary according to whatever optimizations it's algorithms make. In other words, you will lose information that was present in the first encoded sequence. It is not a case of just putting you information into a larger bucket, some of it is going to get spilled in the process. Link to comment Share on other sites More sharing options...
andrgl Posted November 20, 2019 Share Posted November 20, 2019 6 hours ago, shooter said: I'm afraid to be misunderstood. Let's take on this example of the bucket. Imagine to replace it for a larger bucket (editing/grading codec). Same portion of water (camera codec). That's my point. Doesn't a stronger intermediate codec help for grading? You’d be putting the same amount of water in a larger bucket. No increase in detail, only an increase in file size. seanzzxx, Geoff CB and KnightsFan 3 Link to comment Share on other sites More sharing options...
newfoundmass Posted November 20, 2019 Share Posted November 20, 2019 Unless you absolutely need to transcode a file to a different codec it is always best to edit the original. Image quality wise there is no added benefit for transcoding, if anything there is a penalty. You can't add what isn't already there. Link to comment Share on other sites More sharing options...
