Administrators Andrew Reid Posted June 6, 2020 Administrators Share Posted June 6, 2020 3 hours ago, Geoff CB said: Yeah that looks really meh. Don't understand why Jim doesn't hand one of these units to someone who knows what they are doing and create interesting visuals. Jim is not in charge any more. It's Jarred. I am sure there will be better footage coming soon. Link to comment Share on other sites More sharing options...
Alt Shoo Posted June 6, 2020 Share Posted June 6, 2020 I’m actually on the email list for the Komodo and should have another correspondence from Jarred next week for the Yellow Komodos. I’m not really excited about it anymore. I’m still very interested in the GFX100 and would rather get that. Still I’m holding off because I think Fuji will release a more “cinema cam” version of the GFX100. Link to comment Share on other sites More sharing options...
Administrators Andrew Reid Posted June 6, 2020 Administrators Share Posted June 6, 2020 I must say the design is damn sexy. A bit different to the usual C200 type isn't it?! Alt Shoo 1 Link to comment Share on other sites More sharing options...
JordanWright Posted June 6, 2020 Share Posted June 6, 2020 Just found this Q&A with a few Komodo owners, warning it is 6 hours long. Link to comment Share on other sites More sharing options...
Administrators Andrew Reid Posted June 6, 2020 Administrators Share Posted June 6, 2020 SIX HOURS Link to comment Share on other sites More sharing options...
Snowbro Posted June 6, 2020 Share Posted June 6, 2020 Around 12:30 he shows a few quick clips, looks better than others I've seen posted for Komodo so far. Link to comment Share on other sites More sharing options...
Super Members BTM_Pix Posted June 6, 2020 Super Members Share Posted June 6, 2020 About two hours in I'd be like this Andrew Reid, Emanuel and sanveer 3 Link to comment Share on other sites More sharing options...
thebrothersthre3 Posted June 6, 2020 Share Posted June 6, 2020 Looks like something on a construction site. IronFilm and maxmizer 1 1 Link to comment Share on other sites More sharing options...
Patrick B. Posted June 6, 2020 Share Posted June 6, 2020 I ended up tuning in for a lot of the stream and leaving it on in the background while I was hanging out. Some of the most interesting things to me: -monochrome sensor Komodo coming after color version is out -Raw is supposedly a different compression than current DSMC2 Red’s (DCT vs JPEG2000?) -Sensor is true global shutter. Previously Jarred said it was a “mode” which confused me a bit. Apparently they originally planned to have a RS and GS mode, but got the DR high enough in the GS mode to where there was no need to keep the RS mode. -Komodo started out as something that could replace GoPros in big films for action sequences but ended up being more powerful than initially expected -has motion sensor(s) that aren’t enabled yet Link to comment Share on other sites More sharing options...
FranciscoB Posted June 7, 2020 Share Posted June 7, 2020 What a shitshow of a promotion for this camera. What happened to specs, good footage and NON 6 HOURS videos? Link to comment Share on other sites More sharing options...
Patrick B. Posted June 7, 2020 Share Posted June 7, 2020 2 hours ago, FranciscoB said: What a shitshow of a promotion for this camera. What happened to specs, good footage and NON 6 HOURS videos? In the Q&A Jarred said they haven't published specs because things are in flux and still changing every day. The models out in the wild are basically beta in terms of firmware, but I believe the hardware is nailed down. Someone posted frame rates and resolution on the Facebook group as well as some R3D files and a global shutter test of a spinning fan. Interestingly, Jarred also said they felt like they had to move up the Komodo launch earlier than they wanted because of what happened with the Hydrogen. So, yeah, I guess they're kind of making it up as they go somewhat, but based on the promising DR chart I saw posted I'm really curious to see how it stacks up against other cameras out there. Link to comment Share on other sites More sharing options...
maxmizer Posted June 7, 2020 Share Posted June 7, 2020 The end will be worse and will cost more than a kinefinity.... IronFilm 1 Link to comment Share on other sites More sharing options...
Patrick B. Posted June 7, 2020 Share Posted June 7, 2020 13 hours ago, maxmizer said: The end will be worse and will cost more than a kinefinity.... I’m curious to see if they can hold to the $6k. So far the custom colors for early adopters are holding to the $7k. And I really curious to see what a monochrome version would be priced at. There aren’t really any reasonably priced monochrome cameras out there since it’s such a niche market (especially for video). Link to comment Share on other sites More sharing options...
Video Hummus Posted June 8, 2020 Share Posted June 8, 2020 Do the people buying the custom colors even know what the specs are? Does an NDA notice appear on the packaging and apply as soon as the tape is broken? Like WTH? It’s a little weird. IronFilm 1 Link to comment Share on other sites More sharing options...
Alt Shoo Posted June 8, 2020 Share Posted June 8, 2020 6 hours ago, Video Hummus said: Do the people buying the custom colors even know what the specs are? Does an NDA notice appear on the packaging and apply as soon as the tape is broken? Like WTH? It’s a little weird. Komodo Specs 6K Super 35 27.03 x 14.25mm (6144 x 3240) Global Shutter Full-sensor up to 6K 40 fps 6K WS at 50 fps 4K at 60 fps 120 fps at 2K 12G-SDI output with 2160p at 60 fps R3D files (REDCODE RAW) 3.5mm microphone/headphone No XLR CFast cards, not dual Wireless video module Touchscreen Display Phase Detection Autofocus Canon RF mount Size: 4″ x 4″ (10.16 cm x 10.16 cm) Weight: 2lbs (900g) approx. It’s been pretty transparent honestly. Link to comment Share on other sites More sharing options...
tweak Posted June 8, 2020 Share Posted June 8, 2020 Specs sound fairly underwhelming, only thing I'd be excited about is redcode. Link to comment Share on other sites More sharing options...
Administrators Andrew Reid Posted June 8, 2020 Administrators Share Posted June 8, 2020 Global shutter is pretty exciting, no? Patrick B. 1 Link to comment Share on other sites More sharing options...
Administrators Andrew Reid Posted June 8, 2020 Administrators Share Posted June 8, 2020 5 hours ago, Alt Shoo said: 6K Super 35 27.03 x 14.25mm (6144 x 3240) Global Shutter Phase Detection Autofocus Canon RF mount The most interesting bits I am wondering who made the sensor. Not many global shutter 6K Super 35mm sensors with PDAF out there from Sony that I know of! The Canon tie-in is obvious. I think this is part of an agreement with Canon doing RAW internal without violating RED patent. Link to comment Share on other sites More sharing options...
IronFilm Posted June 8, 2020 Share Posted June 8, 2020 On 6/7/2020 at 3:46 PM, Patrick B. said: In the Q&A Jarred said they haven't published specs because things are in flux and still changing every day. The models out in the wild are basically beta in terms of firmware, but I believe the hardware is nailed down. Someone posted frame rates and resolution on the Facebook group as well as some R3D files and a global shutter test of a spinning fan. RED is amazing with their marketing, they're getting folks to PAY to be beta testers! Snowbro, sanveer, ntblowz and 1 other 1 3 Link to comment Share on other sites More sharing options...
gt3rs Posted June 8, 2020 Share Posted June 8, 2020 If the image quality DR and AF is good it seems like a cool camera for the price. Wish it had CFexpress instead of CFast Patrick B. 1 Link to comment Share on other sites More sharing options...
