zerocool22 Posted November 26, 2019 Share Posted November 26, 2019 So if you work with these, you would get the same(similar) starting point as alexa footage(without the DR)? But if you throw in some Alexa luts afterwards will they clip on the pocket 4K? Sage 1 Link to comment Share on other sites More sharing options...
Sage Posted November 26, 2019 Author Share Posted November 26, 2019 47 minutes ago, Video Hummus said: Hopefully we will see a Gen.4 for GH5S. Great work these look incredibly similar. Thanks Video Hummus; the S will be Gen.4 right out of the gate, and that is the very next camera (along with the GH5 update) 21 minutes ago, zerocool22 said: So if you work with these, you would get the same(similar) starting point as alexa footage(without the DR)? But if you throw in some Alexa luts afterwards will they clip on the pocket 4K? The core conversion is to a measured LogC (what Alexa records to). Then there are the display variations, which include the 709 display primaries from Arri all-in-one. Then there are the display look-ups from Arri itself (to be added to LogC), and their Rec 709 does clip far gamut. Link to comment Share on other sites More sharing options...
Jonesy Jones Posted November 26, 2019 Share Posted November 26, 2019 Will be buying this Thanksgiving weekend. Link to comment Share on other sites More sharing options...
deezid Posted November 26, 2019 Share Posted November 26, 2019 4 hours ago, Sage said: Sure, take non-jpg stills, my email is emotivecolor@gmail.com Braw still frames are also possible via Resolve RAW tab. Sage 1 Link to comment Share on other sites More sharing options...
Sage Posted November 27, 2019 Author Share Posted November 27, 2019 6 hours ago, deezid said: Braw still frames are also possible via Resolve RAW tab. *That's a better idea @Jonesy Jones Let me know what you think! Jonesy Jones 1 Link to comment Share on other sites More sharing options...
BopBill Posted November 30, 2019 Share Posted November 30, 2019 I have played a little with these luts today (daylight and tungsten) and I like what I see. Proper exposure and whitebalance and picture look really nice with healthy skin tones. Good job! I let the more advanced users to comment more later. wyrlyn 1 Link to comment Share on other sites More sharing options...
Anaconda_ Posted December 3, 2019 Share Posted December 3, 2019 At the same price, what's the difference between this LUT and the One LUT? (Aside from light source options) https://www.j-ballard.com/theonelut Link to comment Share on other sites More sharing options...
deezid Posted December 3, 2019 Share Posted December 3, 2019 1 hour ago, Anaconda_ said: At the same price, what's the difference between this LUT and the One LUT? (Aside from light source options) https://www.j-ballard.com/theonelut That's one of the worst luts made for this camera and does in no way match with an ARRI Alexa while Sage's conversion is spot on. Anaconda_ 1 Link to comment Share on other sites More sharing options...
Anaconda_ Posted December 3, 2019 Share Posted December 3, 2019 Seems like a pretty big difference. Thanks! Link to comment Share on other sites More sharing options...
JeremyDulac Posted December 3, 2019 Share Posted December 3, 2019 6 hours ago, Anaconda_ said: At the same price, what's the difference between this LUT and the One LUT? (Aside from light source options) https://www.j-ballard.com/theonelut That lut is literally not in the same universe as the level of work Alex has done here. I doubt that person profiled each camera - it looks more like hue curve adjustments in Resolve. Anaconda_, heart0less, jackch2n and 1 other 4 Link to comment Share on other sites More sharing options...
Sage Posted December 5, 2019 Author Share Posted December 5, 2019 jackch2n, wyrlyn, deezid and 1 other 4 Link to comment Share on other sites More sharing options...
jack jin Posted December 6, 2019 Share Posted December 6, 2019 @Sage Hi, I love your ghalex v3 luts on my g7, and since i have recently upgraded to pocket 4k, I intend to purchase the lut again, but I have a question. When I put on the tungsten lut instead of the daylight lut in the same lighting conditions and white balance, the only difference that I found was a redder skintone, so is it ok if I just use the daylight luts across everything? Or will the color accuracy be sacrificed? Link to comment Share on other sites More sharing options...
majoraxis Posted December 6, 2019 Share Posted December 6, 2019 17 hours ago, Sage said: Beautiful footage - great skin tones. Thanks for the tutorial! On the tutorial was the Blackmagic LUT applied after the skin tone magenta shift compensation node and the black level compensation node? Basically are all things equal except for the LUTs? Either way the Emotive Color LUT is outstanding! Thanks! Link to comment Share on other sites More sharing options...
MeanRevert Posted December 6, 2019 Share Posted December 6, 2019 If I understand it correctly, those PRE and POST adjustments are just for exposure and black levels. Why not just use the Resolve wheels to correct? Link to comment Share on other sites More sharing options...
Sage Posted December 6, 2019 Author Share Posted December 6, 2019 @jack jin Sure; you'll find the P4K to be similar. The summary of it is that Day will be greener under tungsten (always ensure skintone maintains contact with the skintone line on the vectorscope afterwards). The whole color space is slightly different, with each color weaving a divergent path up through the space. @majoraxis Thanks majoraxis, all things are equal up to the cube; ABL must follow the conversion node, and is only on P4Ka for the comparison. WB is actually on the raw clip itself rather than a node (unlike GHa), as the Camera Raw tab is used for a completely accurate WB adjustment @MeanRevert These are good notes for my next tutorial revision The Pre and Posts are much better - Exp Comp Pres are actually complete color conversions that capture the difference in sensor response with varying brightness (they include the rolloff and brighter than 1.0 region as well). And they are incredibly precise to actually stopping up or down in camera (preserving core LogC accuracy). The Posts simply have hue lock built in, and are an optimal luminance adjustment (preserving linearity above black). They are really fast to use, and are a major time saver. They also have a negative region preserved (below 0.0), and therefore not destructive to dark saturation data. That said, for a film, additional luminance adjustment after Post is recommended, to conform the scene details to cinema standard scene luminance (supplemental waveforms) Link to comment Share on other sites More sharing options...
IronFilm Posted December 6, 2019 Share Posted December 6, 2019 On 11/26/2019 at 3:55 PM, Sage said: The G9 just received 10 bit - I wonder if they will update the G7? Currently, Cine-D is supported via a Pre to convert to VLog - Cine-D PRE Would be amazing if the old old G7 gets a 10bit update, but I very very very highly highly doubt that! Doubt even the older lower end G85 would get it (and anyway, a G90 would get it first). Link to comment Share on other sites More sharing options...
Sage Posted December 7, 2019 Author Share Posted December 7, 2019 Mmm, even with the GH5, I often hear of the green/red macroblock codec issue at 10 bit (really just a codec situation moreso than 10 bit). If the 8 bit is really good, and a cleverly stored 709 format, it could work. Link to comment Share on other sites More sharing options...
funkyou86 Posted December 7, 2019 Share Posted December 7, 2019 Hey Sage, might be a stupid question but how is your lut different from resolves color space transform plugin? I can see that you put enormous work and resource to this project and I pretty much love it, i'd just like to know if the final results are different or not Thanks a lot, cheers! JordanWright 1 Link to comment Share on other sites More sharing options...
Sage Posted December 7, 2019 Author Share Posted December 7, 2019 Sure, Resolve CST is a whitepaper transform, according to the manufacturer spec for the formats. EC is a measured LogC under sunlight and halogen. EC has a unique 709 display component that maintains full gamut (exceeding Arri 709). P4K CST LogC+Arri 709: P4K EC 709: funkyou86 1 Link to comment Share on other sites More sharing options...
majoraxis Posted December 7, 2019 Share Posted December 7, 2019 @Sage Thanks the great example! Seems like EC is the way to get the most out of the Pocket 4K sensor In a single conversion/transformation (I’m not considering white balance and black point adjustments as a conversation/transformation for RAW or BRAW footage.) So would having a set of EC LUTS for emulation film stock or an ideal sensor response LUT would benefit from having an EC LUT for each target output to do it in a single conversion? Also, is there the concept of having different EC LUT versions that are tuned for high and low dynamic range scenes as well as the standard EC LUT? Or maybe this does not apply and only one EU daylight LUT is need for any amount of dynamic range in an daylight light scene? Sage 1 Link to comment Share on other sites More sharing options...
