Magic Lantern Raw - Issue with Raw Magic
rtwomey
Hi,
Over the weekend I shot a short film using the Magic Lantern raw hack on a 5D mk III. Everything went perfectly and now I want to make proxies for the director to start his edit.
The problem I'm running into this time is spanned 4gb+ files. I used automator to rename all of the files in each card with a naming scheme of r001c0001 and so on. R for roll and C for clip. When I dump all of these files into RawMagic it only see the takes that are in smaller than 4gb or unspanned. I assume by messing with the file naming I've broken the link between the spanned files.
Can anyone think of a solution for this problem?
Combine first, then rename.
Ditto, and I'll elaborate.  If the footage is important to you, archive/save the original files.  Then develop a workflow from there, always considering you might have to go back to a certain step and start again.
