Super Members BTM_Pix Posted August 28, 2020 Author Super Members Share Posted August 28, 2020 3 minutes ago, Anaconda_ said: @BTM_Pix Thanks for very quick and effective responses, and I'm sure many people were grateful got your email about this issue, but I think you may need to send another as BMD have released a new update expected to fix the Bluetooth. I'm going to test it out this evening, and will happily report back if you'd like. https://www.blackmagicdesign.com/support/readme/a801de7e49a744b7aad008a438f27d35 Check your inbox in about 90 seconds 😉 We downloaded and tested it early this morning and all is good now. Anaconda_ 1 Link to comment Share on other sites More sharing options...
Super Members BTM_Pix Posted September 12, 2020 Author Super Members Share Posted September 12, 2020 On 8/23/2020 at 12:19 PM, Anaconda_ said: That's amazing. I noticed audio controls aren't on any of the ios apps either, so feared it might be like the stills function, and not possible over bluetooth. Good news. Control of the audio levels for both channels has now been incorporated and will be in the PBC firmware update that will be released to support the AFX (though its not dependent on buying an AFX !). Link to comment Share on other sites More sharing options...
Anaconda_ Posted September 12, 2020 Share Posted September 12, 2020 That is amazing news! Looking forward to the update and AFX pre-orders ! BTM_Pix 1 Link to comment Share on other sites More sharing options...
Anaconda_ Posted September 16, 2020 Share Posted September 16, 2020 One more request / suggestion: Is there a way to implement the Window Sensor mode? Assuming the camera's already set to shoot ProRes 1080p, having the window mode at your fingertips would be really cool. It would make the 18-35mm lens even better for any run'n'gun situation. Link to comment Share on other sites More sharing options...
Super Members BTM_Pix Posted September 17, 2020 Author Super Members Share Posted September 17, 2020 On 9/16/2020 at 8:34 AM, Anaconda_ said: One more request / suggestion: Is there a way to implement the Window Sensor mode? Assuming the camera's already set to shoot ProRes 1080p, having the window mode at your fingertips would be really cool. It would make the 18-35mm lens even better for any run'n'gun situation. Yes, it can be implemented but we tend to avoid anything that will make a destructive difference to the recording format. If BM had something on the camera screen that indicated it was in window mode then it would be safer and I suspect that it is why its not available to be mapped to one of their function keys even though it is a very useful tool to have. It is slightly different with the PBC because it would be a very deliberate process to go into setup and assign it (and it could be mapped to a long press so its more difficult to trigger accidentally) so it might be possible to consider it for the benefit of consenting adults in a future update. Link to comment Share on other sites More sharing options...
