landulf Posted November 26, 2013 Share Posted November 26, 2013 Im new to this and have a question. If I shot with a anamorphic 70 mm lens and a 85 mm taking lens, then whats the true focal length? If I shot with only a 50 mm then its 50 mm, but here its easy to get confused. Link to comment Share on other sites More sharing options...
dhessel Posted November 26, 2013 Share Posted November 26, 2013 It should be the roughly the focal length of the taking lens divided by the stretch factor of the anamorphic. An anamorphic lens doesn't have a focal length unless it has a built in taking lens so I have no Idea how you can have a 85mm lens attached to a 70mm anamorphic. Link to comment Share on other sites More sharing options...
QuickHitRecord Posted November 26, 2013 Share Posted November 26, 2013 (Lens focal length x Sensor crop factor) / Anamorphic stretch factor Link to comment Share on other sites More sharing options...
Sebastien Farges Posted November 26, 2013 Share Posted November 26, 2013 (Lens focal length x Sensor crop factor) / Anamorphic stretch factor in the width, not in the height ;) Link to comment Share on other sites More sharing options...
Stanley Hsu Posted November 26, 2013 Share Posted November 26, 2013 (Lens focal length x Sensor crop factor) / Anamorphic stretch factor For example, I use a 2X anamorphic with a 50mm lens on the GH3 (sensor crop factor 2X) (50mm x 2) / 2 = 50mm So I actually get a 50mm image with the GH3. Correct? Link to comment Share on other sites More sharing options...
Gábor Ember Posted November 26, 2013 Share Posted November 26, 2013 Horizontally yes. Link to comment Share on other sites More sharing options...
landulf Posted November 26, 2013 Author Share Posted November 26, 2013 So if I use my sankor 16D x2 with a nikkor 85 mm I get 85x2=170. 170/2=85. So is 85 correct? Link to comment Share on other sites More sharing options...
QuickHitRecord Posted November 26, 2013 Share Posted November 26, 2013 So I actually get a 50mm image with the GH3. Correct? Yes, that would be the field of view (horizontally). However, this can actually change slightly if you have a lens that breathes. For instance, a close up shot might offer a true 2x stretch, but focusing to infinity with the same lens may give you a 1.7x stretch or a 1.8x stretch, and that can affect your final field of view. But this formula is good for a ballpark number. So if I use my sankor 16D x2 with a nikkor 85 mm I get 85x2=170. 170/2=85. So is 85 correct? If you are using a camera with a 2x crop sensor, then yes. GH3 and 2x lenses are always the easiest to calculate. Link to comment Share on other sites More sharing options...
landulf Posted November 26, 2013 Author Share Posted November 26, 2013 I have a canon 5dmk2.. Link to comment Share on other sites More sharing options...
Gábor Ember Posted November 26, 2013 Share Posted November 26, 2013 In that case your lens behaves vertically as a 85mm (vertically you get the same field of view as if you were only using your nikkor) and horizontally as a 42.5mm (horizontal field of view extended). Link to comment Share on other sites More sharing options...
richg101 Posted November 26, 2013 Share Posted November 26, 2013 forget sensors in the equation IMO. the focal length of your lens remains what ever the taking lens is. So any anamorphic lens in front of a 85mm is still a 85mm. fov on the vertical remains the same as when you use the 85mm lens without the anamorphot. fov on the horizontal depends on the squeeze ratio. Yours being a 2x anamorphic will result in a horizontal fov of a 42mm lens when used on your 85mm taking lens. Link to comment Share on other sites More sharing options...
richg101 Posted November 26, 2013 Share Posted November 26, 2013 factoring in your full frame sensor... your 85mm will give you the same fov as a 50mm lens on a super 35mm sensor. thus.. with the anamorphic lens and a 3.55:1 ratio you'll see the 50mm vertical fov most would expect from a s35mm sensor, and a horizontal fov of 25mm in the same terms. if you crop to 2.40 the horizontal fov will be the same as what you would expect from a non anamorphic lens of roughly 35-40mm in focal length Link to comment Share on other sites More sharing options...
landulf Posted November 27, 2013 Author Share Posted November 27, 2013 Thanks... Link to comment Share on other sites More sharing options...
landulf Posted December 4, 2013 Author Share Posted December 4, 2013 But what focal length do u get if you put on a diopter +1 and +2 etc…? Link to comment Share on other sites More sharing options...
dhessel Posted December 4, 2013 Share Posted December 4, 2013 Diopters only effect focus distance and will have little/no effect on focal length. Link to comment Share on other sites More sharing options...
