180 VR immersive film-making
kye
  • Super Members
27 minutes ago, no_connection said:
That was a great introduction to VR180. Would have liked some binaural mic tho. Imagine some high quality ASMR.
If you want to dip a toe into binaural recording in a budget self contained unit then I have the Zoom H3-VR which is a pretty good unit.
It records the audio internally in multi channel ambisonic format but also provides a live binaural stereo downmix  to record to your camera.
This gives you the option to post-produce the ambisonic files or just go with a binaural version on the camera as with this example I did here with the OG Pocket camera.
There are links to the original files and the free Zoom Ambisonics player so you can play around with the possibilities here
I was thinking that too.  Even a stereo pair placed above the camera mixed in would give some sense of space.
The best solution would be to decode a 3D signal to binaural output based on your viewing angle, but do we know if the platforms support this kind of encoded sound, or if they just pump out a stereo audio track?
I figure that we're in the infancy of this stuff, and it will get there, but not really sure how far the tech is along right now w.r.t audio.  I do know that in terms of adjustability it's normally pretty rubbish.  I have MobileVRStation for iOS and the number of options in it is ridiculous, and the number of options in most online streaming platforms is zero.
  • Super Members
The H3-VR has a six axis motion sensor so it always knows its position relative to the "front" of the camera and encodes internally in Ambix (used for YouTube and Facebook 360 stuff) and FuMa (usually for games) formats so everything remains in sync with viewing angle.
Considering how long Ambisonic recording has been with us (I was selling those Soundfield microphones almost 30 years ago now and even then it wasn't new), it is the video tech that is in its infancy really.
  • Super Members
If you have some time, you should download the free Zoom Ambisonics player and the original files from that thread and have a play with those to see how you can move the listening position when set to Binaural.
If you have a 5.1 system connected to your Mac then so much the better when you set it to that but unrealistic for how people will be consuming VR on headphones obviously.
The 190526_001.WAV file has the constant source of the fountain so is a good example of how far you can shift things.
I'd give a recommendation for the Zoom H3-VR as well, is crazy insanely cheap. Every VR hobbyist should have it.
Although if you want to take it more seriously at a semi professional level, then get a Rode NT-SF1 / Zoom F8n kit instead, which is itself insanely good value for money as well, and will be another level above the H3-VR
Yes, the usual platforms (Facebook / YouTube / etc) all support ambisonics
For decades ambisonics was "a solution looking for a problem"
Well it has found its problem, VR! Perfect match.
