Henry Gentles Posted January 4, 2014 Share Posted January 4, 2014 I bought a Cosmicar 25mm 1.8 C mount lens. I'm pretty sure it has a focus problem. The aperture works fine but the lens does not move and does not focus. ie There is no movement in the focal length when I wind in or out. Can I fix this? I am an Audio Engineer and Electronic Tech so I have the tools etc to pull this apart and have a nosy!! Can anyone direct me to a link or tutorial as I've never pulled a Lens apart before? (And if I can't fix it, I can fix it so that no one can!!) ;) Link to comment Share on other sites More sharing options...
andy lee Posted January 4, 2014 Share Posted January 4, 2014 there is a collar that has grub screws securing it to the innards of the lens are these grub screws secure?? if not it will just rotate and not focus I had this issue on a Cosmicar /Pentax 25mm f1.4 c mount lens , tighten them up and it works ok Gábor Ember 1 Link to comment Share on other sites More sharing options...
Henry Gentles Posted January 5, 2014 Author Share Posted January 5, 2014 Do you mean the silver collar of the mount or inside the lens? Link to comment Share on other sites More sharing options...
Gábor Ember Posted January 5, 2014 Share Posted January 5, 2014 On the actual focus ring. Link to comment Share on other sites More sharing options...
