Dr. John R. Brinkley Posted January 12, 2014 Share Posted January 12, 2014 I have a BMPCC for video but want a small used camera for stills. I'd like to spend $350 or less via eBay. Ideally with a zoom lens included. I want MFT so that whatever lens it comes with could also be used on the pocket. GF1? GF3? GX1? Something else I'm not considering? Appreciate any feedback. Link to comment Share on other sites More sharing options...
andy lee Posted January 12, 2014 Share Posted January 12, 2014 my gf3 is good for stills but not as good as my g6 which very good ......almost as good as my canon gf3 is a superb little camera but only auto iso , there is no manual iso setting on it you can get a g6 on ebay now very cheap Link to comment Share on other sites More sharing options...
tosvus Posted January 13, 2014 Share Posted January 13, 2014 If you want IBIS the only pana that has it is gx7 (pricey) Olympus has it standard though only a few expensive models have the lauded 5 axis version. Link to comment Share on other sites More sharing options...
Julian Posted January 13, 2014 Share Posted January 13, 2014 Olympus has better sensors for still photography. The PEN E-PM2 and EP-L5 have the same sensor as the OM-D E-M5. You should be able to get a E-PM2 with kitlens for $350. The sensor is a lot better than the one in the cheap Panasonic camera's like the GF3/GX1 and also beats the G6 for still photography. Link to comment Share on other sites More sharing options...
maxotics Posted January 13, 2014 Share Posted January 13, 2014 You can get GF3 bodies for $100 and use any of your MFT lenses on them. The camera is nice and small. I have one. I also have a Sigma DP2s. That's what I want to take out, and do, if light is good. Some basic things I want to point out. 1. Larger sensor wins over small sensor 2. Fixed prime lens engineered to sensor wins (Sigma DPs, Fuji X100S, Sony RX1, Ricohs) 3. Zoom lenses aren't very good until you get over the $1,000 range. Bottom line, the GF3 is all the camera you need to shoot stills in MFT. If you want a real "film" like camera you need to spend at least $700 (or find something used) and I'd go with Fuji or Sigma. I'd also consider the Canon Gx1, used. Link to comment Share on other sites More sharing options...
Julian Posted January 13, 2014 Share Posted January 13, 2014 The PENS have two more stops of dynamic range than the GF3... It's EM-5 image quality, which is good. As good as Canon APS-C. andy lee 1 Link to comment Share on other sites More sharing options...
Dr. John R. Brinkley Posted January 13, 2014 Author Share Posted January 13, 2014 I'm not looking to spend $700 though I'm sure I would appreciate the image more. The wife will use this camera as well so something with some auto features for her and manual features for me would be a good balance. I was intrigued by lumix because their lenses have IS on the lens which would benefit the Pocket camera. However, IS on the olympus body would allow me an advantage to use old legacy glass with dumb adapters. Based on all these suggestions I'll look into the Olympus to see if I can afford the PEN models. I appreciate the feedback. Link to comment Share on other sites More sharing options...
Julian Posted January 13, 2014 Share Posted January 13, 2014 EPM2 kit is on ebay for $350. Not sure if the Panasonic OIS works on the Pocket.. have heard stories of it not working. Link to comment Share on other sites More sharing options...
Quirky Posted January 13, 2014 Share Posted January 13, 2014 I have a BMPCC for video but want a small used camera for stills. I'd like to spend $350 or less via eBay. Ideally with a zoom lens included. I want MFT so that whatever lens it comes with could also be used on the pocket. GF1? GF3? GX1? Something else I'm not considering? Appreciate any feedback. Okay, here's some feedback from a slightly different angle; As long as we're talking about a camera for stills only, and given that you can (and probably will, eventually) get a Speed Booster for the BMPCC, why would you limit your options to mFT only? After all, given the 3x crop factor of the BMPCC, getting a Speed Booster for it is a no-brainer, and "small" is not exclusive to mFT only, not any longer. You also mention a zoom lens, but would it have to be an interchangeable one, or could a smart compact camera do as well? If you plan on carrying that one zoom lens only, you might as well get along with a smart compact camera, too. Even if you do want and need an interchangeable lens camera, the BMPCC doesn't really limit your choice of stills camera brand. There are adapters for other brands and lens mounts, too. So if you fancy some other brand or model more than Olysonic, go for it. Well, just a thought, or two. Link to comment Share on other sites More sharing options...
Dr. John R. Brinkley Posted January 13, 2014 Author Share Posted January 13, 2014 I should add that I'm planning/considering buying a mft prime this year for wide angle on the pocket, especially if Kowa finally releases/rebrands there mft lenses, such as the 8mm and 12mm. Given this I'm going with mft for the moment. Link to comment Share on other sites More sharing options...
maxotics Posted January 14, 2014 Share Posted January 14, 2014 EPM2 kit is on ebay for $350. Not sure if the Panasonic OIS works on the Pocket.. have heard stories of it not working. It works if the lens has an external OIS switch, at least it does on my 14-45 OIS lens. Julian 1 Link to comment Share on other sites More sharing options...
maxotics Posted January 14, 2014 Share Posted January 14, 2014 The wife will use this camera as well so something with some auto features for her and manual features for me would be a good balance. All I can say is GOOD LUCK WITH THAT! :) I generally follow the advice with my wife, "never buy them something with a cord or blinking light. They won't like it." I went out and took some test shots with my DP2S and GF3/14mm. I was expecting the DP2S to do better than the GF3. It didn't do well enough to be worth the headaches of Sigma. That's good! I think the camera for you is the GX7. I'm considering it myself. It has built in sensor stabilization so can supposedly shoot at 1/10th of a second hand held. That would be like getting a f1.0 lens for me! I have suspicions that they achieve this through a hidden increase in ISO, but who knows? The other benefit of the GX7 is it has a viewfinder. My old eyes really need that. About the PEN cameras. I bought a used 1st generation one and was blown away by how good it was. So I wouldn't be surprised if what the other posters say about better still quality. Link to comment Share on other sites More sharing options...
