Cassius McGowan Posted February 8, 2020 Share Posted February 8, 2020 Quick question guys and girls. About to make a purchase of Ebay for a lens filter but it has no threads. Seller said that the filter needs an adapter. Could anyone post me in the right direction on this because I'm about to go crazy searching for this info. LOL Thanks in advance. Oh and the thread is 82mm btw. Link to comment Share on other sites More sharing options...
heart0less Posted February 8, 2020 Share Posted February 8, 2020 Umm, is it a circular filter or a square one? We need some more info to help you. Link to comment Share on other sites More sharing options...
FranciscoB Posted February 8, 2020 Share Posted February 8, 2020 is it cokin or lee filters type? See if that fits your situation. There are other similar systems. Link to comment Share on other sites More sharing options...
noone Posted February 8, 2020 Share Posted February 8, 2020 A lot of larger size lenses use filter holders with filters to fit. I have a polariser with filter holder for my Canon 17mm tilt shift lens (not that i use it much) that fits on the front of the lens. Then there are also some filters that fit into rear filter holders on a few lenses (EG Canon 17-40 L) and some longer telephotos have a filter holder that slots into the lens (means a small filter can be used on a large lens...EG my old 300mm 2.8 Tamron adaptall).. Link to comment Share on other sites More sharing options...
Cassius McGowan Posted February 8, 2020 Author Share Posted February 8, 2020 9 minutes ago, heart0less said: Umm, is it a circular filter or a square one? We need some more info to help you. It's a promist filter 82mm circular. 6 minutes ago, FranciscoB said: is it cokin or lee filters type? See if that fits your situation. There are other similar systems. It's a Black promist filter 82mm circular. Link to comment Share on other sites More sharing options...
KnightsFan Posted February 8, 2020 Share Posted February 8, 2020 It may be a Series 9 filter, which is a format of 82mm non-threaded filter. Ask the seller if it's Series 9, or Lee, or what format it is. Most filters can be found in a number of formats, e.g. you can find a Black ProMist in 77mm standard threaded, or Series 9, or square formats. You should definitely find out for sure what standard the filter is before buying so you know what kind of adapter you'll need and how expensive that will be. Link to comment Share on other sites More sharing options...
Cassius McGowan Posted February 8, 2020 Author Share Posted February 8, 2020 1 minute ago, KnightsFan said: It may be a Series 9 filter, which is a format of 82mm non-threaded filter. Ask the seller if it's Series 9, or Lee, or what format it is. Most filters can be found in a number of formats, e.g. you can find a Black ProMist in 77mm standard threaded, or Series 9, or square formats. You should definitely find out for sure what standard the filter is before buying so you know what kind of adapter you'll need and how expensive that will be. That's what it is. IT's a series 9 2 minutes ago, KnightsFan said: It may be a Series 9 filter, which is a format of 82mm non-threaded filter. Ask the seller if it's Series 9, or Lee, or what format it is. Most filters can be found in a number of formats, e.g. you can find a Black ProMist in 77mm standard threaded, or Series 9, or square formats. You should definitely find out for sure what standard the filter is before buying so you know what kind of adapter you'll need and how expensive that will be. So what do i need to purchase for a series 9 filter? Link to comment Share on other sites More sharing options...
tupp Posted February 8, 2020 Share Posted February 8, 2020 6 minutes ago, KnightsFan said: It may be a Series 9 filter Beat me to it! 6 minutes ago, Cassius McGowan said: So what do i need to purchase for a series 9 filter? Here are some Series 9 holders. Link to comment Share on other sites More sharing options...
Cassius McGowan Posted February 8, 2020 Author Share Posted February 8, 2020 Thanks for all the info guys!! 👍 Link to comment Share on other sites More sharing options...
