Administrators Andrew Reid Posted February 20, 2020 Administrators Share Posted February 20, 2020 X-H2 anyone? With the X-T4 confirmed to be staying at 4K, a big 8K door swings opens for a higher spec hybrid camera from Fujifilm. https://www.eoshd.com/news/is-this-the-fuji-x-h2-sensor-with-12bit-8k/ Emanuel and Trankilstef 2 Link to comment Share on other sites More sharing options...
Video Hummus Posted February 21, 2020 Share Posted February 21, 2020 Need to change the site name to FUJIHD to reflect the new reality. Emanuel, IronFilm, frontfocus and 1 other 3 1 Link to comment Share on other sites More sharing options...
Administrators Andrew Reid Posted February 21, 2020 Author Administrators Share Posted February 21, 2020 To reflect reality the site name would have to change every month! andrgl, JR Lipartito, Geoff CB and 5 others 1 7 Link to comment Share on other sites More sharing options...
thebrothersthre3 Posted February 21, 2020 Share Posted February 21, 2020 Interesting, it puzzles me that 8k is already on the table when it seems like everyone is still struggling to pull of 4k without overheating. heart0less and IronFilm 2 Link to comment Share on other sites More sharing options...
Administrators Andrew Reid Posted February 21, 2020 Author Administrators Share Posted February 21, 2020 Panasonic S1H already doing 6K so not a huge leap to 16:9 tv standard "8K" which is actually 7.6K resolution horizontal. 5.5K 60p is about the same datarate too and that is here in 1D X III Smartphones may soon have 8K in very small, thin fanless encasings, with tiny thin copper heatsinks So yes it is very doable in 2020, but will it be any use or any good, or just a marketing label? We'll soon find out Emanuel 1 Link to comment Share on other sites More sharing options...
thebrothersthre3 Posted February 21, 2020 Share Posted February 21, 2020 2 hours ago, Andrew Reid said: Panasonic S1H already doing 6K so not a huge leap to 16:9 tv standard "8K" which is actually 7.6K resolution horizontal. 5.5K 60p is about the same datarate too and that is here in 1D X III Smartphones may soon have 8K in very small, thin fanless encasings, with tiny thin copper heatsinks So yes it is very doable in 2020, but will it be any use or any good, or just a marketing label? We'll soon find out True though smart phones use much smaller sensors, which is how I'd imagine they pull it off unless the tech is just more advanced (better funding for products I'd assume). The S1H does 6k but its also a huge body with vents and fans. Can Fuji do it without making a huge body? I mean I really don't mind bigger bodies so I don't care. Link to comment Share on other sites More sharing options...
androidlad Posted February 21, 2020 Share Posted February 21, 2020 It's stacked but doesn't have DRAM. Link to comment Share on other sites More sharing options...
keessie65 Posted February 21, 2020 Share Posted February 21, 2020 If this is all true, I'll probably wait for it. Perhaps not buying X-T4 Emanuel 1 Link to comment Share on other sites More sharing options...
JurijTurnsek Posted February 21, 2020 Share Posted February 21, 2020 Imagine the kind of heat Sony could produce with this baby! HOT, HOT, HOT! Seriously, though, I hope Sony releases an APS-C body with bullet-proof 4K60p before they hop on the 8K bandwagon and RS from hell. Link to comment Share on other sites More sharing options...
Trek of Joy Posted February 21, 2020 Share Posted February 21, 2020 What we do know, Sony will never have a Alpha camera with this sensor before Nikon and Fuji. And no way they can manage sufficient heat dissipation in the tiny a6000 bodies. They've said repeatedly the APS-c philosophy is about being more compact - hence sticking with the a6000 form factor. I've given up hope they'll release a APS-c body using the a7/9 chassis. Its never going to happen, the clickbait SAR chatter about a mythical a7000 is rubbish, they're keeping it exclusively for FF. As to this sensor, my guess is 8k is coming to the FS7mk3 with something like this. Chris Link to comment Share on other sites More sharing options...
Administrators Andrew Reid Posted February 21, 2020 Author Administrators Share Posted February 21, 2020 7 hours ago, androidlad said: It's stacked but doesn't have DRAM. How does this work then? I thought stacked = DRAM mounted on back of sensor. Link to comment Share on other sites More sharing options...
androidlad Posted February 21, 2020 Share Posted February 21, 2020 1 hour ago, Andrew Reid said: How does this work then? I thought stacked = DRAM mounted on back of sensor. BSI Stacked vs. BSI Stacked with DRAM: DRAM is an additional stack which improves read speed even further. Other than mobile phone sensors, it's reserved for A9 type camera. Link to comment Share on other sites More sharing options...
hoodlum Posted February 21, 2020 Share Posted February 21, 2020 Wouldn't this stacked sensor have DRAM due to the 120fps readout? 25 minutes ago, androidlad said: BSI Stacked vs. BSI Stacked with DRAM: DRAM is an additional stack which improves read speed even further. Other than mobile phone sensors, it's reserved for A9 type camera. Link to comment Share on other sites More sharing options...
androidlad Posted February 21, 2020 Share Posted February 21, 2020 Just received info from a source that, X-H2 (or whatever the next gen rugged flagship is called) will have integrated battery grip, like this: Link to comment Share on other sites More sharing options...
hoodlum Posted February 21, 2020 Share Posted February 21, 2020 I wonder if we will see the same complaints that the E-M1x had. Link to comment Share on other sites More sharing options...
thebrothersthre3 Posted February 21, 2020 Share Posted February 21, 2020 Not sure if I see a point to a built in battery grip. Doesn't that mean you lose the internal battery? Meaning you get two batteries total rather than 3? Link to comment Share on other sites More sharing options...
keessie65 Posted February 21, 2020 Share Posted February 21, 2020 23 minutes ago, androidlad said: Just received info from a source that, X-H2 (or whatever the next gen rugged flagship is called) will have integrated battery grip, like this: I hope not... Geoff CB 1 Link to comment Share on other sites More sharing options...
Amazeballs Posted February 21, 2020 Share Posted February 21, 2020 Same here. X-H2 with integrated grip will be a no-buy for me. Too bulky. There is just no point of sticking to APC-S for such a bulky camera for me. Link to comment Share on other sites More sharing options...
Video Hummus Posted February 21, 2020 Share Posted February 21, 2020 Integrated battery grips for everybody! Link to comment Share on other sites More sharing options...
hoodlum Posted February 21, 2020 Share Posted February 21, 2020 1 minute ago, Video Hummus said: Integrated battery grips for everybody! Does that mean the GH5 will have an integrated battery grip as well? 😮 Link to comment Share on other sites More sharing options...
