mirekti Posted March 21, 2020 Share Posted March 21, 2020 So I bought the slider and like it a lot, however the ballhead it came with is not ideal for my setup. Can anyone recommend a ballhead that I could use instead? The “only” issue is I am using manfroto based plate so it has to be compatible in order to easily move it from tripod (E-Image GH06 ballhead), monopod and slider. As you can see in the second photo I use some cheap manfrotto based base on the original ballhead, but it keeps unscrewing. I cannot screw it in tight enought as the ball starts spinning at one point. Whatever I found was arca swiss based. Link to comment Share on other sites More sharing options...
Gregormannschaft Posted March 21, 2020 Share Posted March 21, 2020 I can’t answer your question but I’d love to ask. I’ve been looking for a cheaper alternative to the Rhino, Edelkrone and Syrp options out there. Have you tested it with heavier cameras at all? And are you able to get smooth motion with small movements? I find the brands above incredibly overpriced and would rather not spend 800 € on what should be simple camera movements. Link to comment Share on other sites More sharing options...
FranciscoB Posted March 21, 2020 Share Posted March 21, 2020 Why not use the slider in-between the tripod legs and the fluid head? I've always used my slider setups like that and never had any problems. Link to comment Share on other sites More sharing options...
mirekti Posted March 22, 2020 Author Share Posted March 22, 2020 6 hours ago, FranciscoB said: Why not use the slider in-between the tripod legs and the fluid head? I've always used my slider setups like that and never had any problems. It would slow me down, and limit the movements. Link to comment Share on other sites More sharing options...
mirekti Posted March 22, 2020 Author Share Posted March 22, 2020 6 hours ago, Gregormannschaft said: I can’t answer your question but I’d love to ask. I’ve been looking for a cheaper alternative to the Rhino, Edelkrone and Syrp options out there. Have you tested it with heavier cameras at all? And are you able to get smooth motion with small movements? I find the brands above incredibly overpriced and would rather not spend 800 € on what should be simple camera movements. My setup is 2, 2.5kg. I like it, but need better ballhead. It is a bit hard to push it up the angle, but doable. Vertical movement might be tricky, going down especially. This review is nice, the only thing missing is variable dampening. Link to comment Share on other sites More sharing options...
