Panasonic S1H gets anamorphic RAW and 6K RAW via HDMI to Atomos Ninja V
5 hours ago, FranciscoB said:
But no cameras are using it. Only recorders and that dji drone. Atomos are the only ones pushing for this.
That’s true. I can’t help but wonder if Apple has some bigger plan in mind. Red had referenced some partnership things happening right around the time the patent was being contested.  I wonder if Apple will have some broader licensing deal that could eventually cover in-camera recording. Maybe eventually after Atomos’ exclusive period passes then we’ll see. Or maybe not.
BRAW for S1H would be very cool though.
3 hours ago, FranciscoB said:
Maybe. Is it true that you can't change your wb with prores raw like other raw files? On paper looks great but I really don't see the appeal of that codec.
I was curious too as I've tested ProRes raw on Premiere Pro beta, and didn't find any ISO or WB setting, like i was used to on other raw format.
So i asked in a group in FB and somebody replied me this
"The reason you had to change those settings in older raw formats is because they were metadata contained in a sidecar file, referencing a folder of still frames for each clip. ProRes RAW is a single file with all the metadata contained inside it. So you adjust it using the same color controls as a regular video clip; like how you would for a raw still in Lightroom."
To me it makes sense, anybody can confirm this?
Yeah that is the case from what I’ve gathered on YouTube.
yeah I also read or heard somewhere that even though you don’t get a raw panel in FCPX any adjustments are still happening in linear space prior to debayer.
