gt3rs Posted April 27, 2020 Share Posted April 27, 2020 I'm looking for some cheap and portable led lights. For bigger things I will rent. I was comparing SLB60w vs Forza 60 as they have similar prices and features: SLB60w advantages: + No cables, a simple one block solution + Bowens mount (no adapted needed) - Reflector less powerful and optimized than the Forza 60 - Proprietary Battery - Expensive AC adapter (cost almost as a SL60w) Forza 60 advantages: + Can be powered by AC included or battery via D-Tap custom cable or has Sony battery adapter. V Mount battery can be used for other things and will last more that the Godox + More brightness thanks to the better reflector + Smaller and less weight on the stand - Not sure but it seems a bit less bright in bar-bulb - Bowens mount via adapter - Power adapter + block instead of a single item - More expensive if you include the battery and charger Anyone has experience with one of them? Link to comment Share on other sites More sharing options...
newfoundmass Posted April 27, 2020 Share Posted April 27, 2020 I don't have experience with either, but have you considered looking into ways to power the Godox SL60w outdoors? I've been looking into it myself. Having a powerful external battery also will have other uses for me that make it appealing. Link to comment Share on other sites More sharing options...
gt3rs Posted April 27, 2020 Author Share Posted April 27, 2020 On 4/27/2020 at 3:16 PM, newfoundmass said: I don't have experience with either, but have you considered looking into ways to power the Godox SL60w outdoors? I've been looking into it myself. Having a powerful external battery also will have other uses for me that make it appealing. Expand I saw that and it could be something but it is heavy and another piece... also did not find something equivalent here in switzerland at a good price. Ideally they should include the AC power in the same price of the SLB60w Link to comment Share on other sites More sharing options...
