zerocool22 Posted January 30, 2021 Share Posted January 30, 2021 18 hours ago, Alfonso A said: There are also other major problems with the video functions. For example, if you try to shoot on HD at a higher frame rate than 60FPS, the gamma curve gets shut off. Color matching L-log shots and high speed shots is virtually impossible. The lens profiles stored only compile leica still lenses. So if you are using leitz or leica cine lenses, you have select a profile that might not be adequate for the lens mounted. For example if you are shooting with a 29mm Summicron-C, there is no profile that matches the focal length. Anyway, seems like they decided to look the other way and not address any of their F-ups with this camera. I guess the sl2s is their answer allthough it might feature other problems. Link to comment Share on other sites More sharing options...
Rrw Posted May 14, 2021 Share Posted May 14, 2021 Hi the problem with the Leica is persistent one year after this important post ! the issue is still unsolved ! is there any information when this problem with the battery during video shooting will be solved by Leica? Link to comment Share on other sites More sharing options...
Administrators Andrew Reid Posted May 15, 2021 Author Administrators Share Posted May 15, 2021 Solution A - the battery grip ($999)! Solution B was the SL2-S. Not a great outcome really. A quite expensive one for users. There was never a firmware update to fix it. Pepe 1 Link to comment Share on other sites More sharing options...
Video Hummus Posted May 15, 2021 Share Posted May 15, 2021 Does the S1R still suffer from the same issue? Link to comment Share on other sites More sharing options...
Pepe Posted January 18 Share Posted January 18 On 1/30/2021 at 10:59 AM, zerocool22 said: I guess the sl2s is their answer allthough it might feature other problems. I would be really intrigued to read a review about the Leica SL2-S from Mr Reid! Now with the SL3 the price of the SL2S on the second hand market has come down.. 👋 Link to comment Share on other sites More sharing options...
