stefanocps Posted July 15, 2020 Share Posted July 15, 2020 Hello i am about to buy a rig for my xt3. I was thinking of the smallrig one. I know there are several options to buy with it.. As it is a present i want to have a quick list of what are the most common and useful things to buy with it. Any help? thanks a lot Link to comment Share on other sites More sharing options...
EphraimP Posted July 15, 2020 Share Posted July 15, 2020 Love the Smallrig cage. I set mine up with a Nato rail on top and a Nato clamp top handle. You'll definitely want a cable clamp that fits whatever type of cables the shooter will use. Link to comment Share on other sites More sharing options...
stefanocps Posted July 15, 2020 Author Share Posted July 15, 2020 you mean this? https://cvp.com/product/smallrig-sr1885-clamp?cur=EU&gclid=Cj0KCQjw0rr4BRCtARIsAB0_48PZsjSO_1uEmgWg4NQmpbUGOk7Os6jurjIAyAMQRc-hORLX1AMpq7YaAmlkEALw_wcB https://www.smallrig.com/smallrig-mini-quick-release-nato-rail-48mm-2172.html the nato clamp is for attach to it other accessories..like a microphone or a monitor for example, right? and the rail? Link to comment Share on other sites More sharing options...
EphraimP Posted July 15, 2020 Share Posted July 15, 2020 10 minutes ago, stefanocps said: you mean this? https://cvp.com/product/smallrig-sr1885-clamp?cur=EU&gclid=Cj0KCQjw0rr4BRCtARIsAB0_48PZsjSO_1uEmgWg4NQmpbUGOk7Os6jurjIAyAMQRc-hORLX1AMpq7YaAmlkEALw_wcB The above product is not what I referred to https://www.smallrig.com/smallrig-mini-quick-release-nato-rail-48mm-2172.html Yes, this is the rail. the nato clamp is for attach to it other accessories..like a microphone or a monitor for example, right? and the rail? Nato rails allow you to attach any number of accessories. I specifically meant using the rail you linked to attach a handle like this one than has an integral nato clap: https://www.smallrig.com/smallrig-camera-camcorder-action-stabilizing-nato-handle-1955.html Handles are great for hand-held shooting and provide a couple of cold shoes for mounting mics or other accessories. The nato clamp styles are very easy to take of if you want to mount the camera on a gimbal. The cage itself has a nato rail built into the left side which can be used for attaching accessories like side handles or monitor arms. Link to comment Share on other sites More sharing options...
stefanocps Posted July 15, 2020 Author Share Posted July 15, 2020 4 minutes ago, EphraimP said: Nato rails allow you to attach any number of accessories. I specifically meant using the rail you linked to attach a handle like this one than has an integral nato clap: https://www.smallrig.com/smallrig-camera-camcorder-action-stabilizing-nato-handle-1955.html Handles are great for hand-held shooting and provide a couple of cold shoes for mounting mics or other accessories. The nato clamp styles are very easy to take of if you want to mount the camera on a gimbal. The cage itself has a nato rail built into the left side which can be used for attaching accessories like side handles or monitor arms. ok i was wondering why you did not mention an handle infact 🙂 what about putting the cage on rails also?what do i need, a part of the rails? Link to comment Share on other sites More sharing options...
EphraimP Posted July 15, 2020 Share Posted July 15, 2020 I use this baseplate, because the cage has a built-in Arca-Swiss style QR plate. It works great on my rig and the height is adjustable. https://www.smallrig.com/smallrig-universal-15mm-rail-support-system-baseplate-2272.html I use Smallrig's aluminum rods on my rig with this. Link to comment Share on other sites More sharing options...
