Administrators Andrew Reid Posted July 23, 2020 Administrators Share Posted July 23, 2020 https://www.smallrig.com/blog/no-more-concerns-about-the-overheating-of-canon-r5/ I like their sense of humour! However you can do the survey too and tell them what you'd like to see. We will definitely get some sort of fan cage from someone! Link to comment Share on other sites More sharing options...
Avenger 2.0 Posted July 24, 2020 Share Posted July 24, 2020 Asked for heatsink and cooling fan integrated into smallrig cage 🤣 However seeing the overheating test Tony did on Youtube, it looks like the (plastic) shell really isolates the inside heat from the outside. Not sure any fan or heatsink at the outside will even do any difference. Link to comment Share on other sites More sharing options...
zerocool22 Posted July 24, 2020 Share Posted July 24, 2020 1 hour ago, Avenger 2.0 said: Asked for heatsink and cooling fan integrated into smallrig cage 🤣 However seeing the overheating test Tony did on Youtube, it looks like the (plastic) shell really isolates the inside heat from the outside. Not sure any fan or heatsink at the outside will even do any difference. Maybe drilling some holes in it will resolve the issue. Allthough it wont be weatherproof anymore. Link to comment Share on other sites More sharing options...
Avenger 2.0 Posted July 24, 2020 Share Posted July 24, 2020 20 minutes ago, zerocool22 said: Maybe drilling some holes in it will resolve the issue. Allthough it wont be weatherproof anymore. And warranty will certainly be void. Hopefully they will bring out a R5 with cooling fan in the future like panasonic did. Link to comment Share on other sites More sharing options...
hijodeibn Posted July 24, 2020 Share Posted July 24, 2020 6 hours ago, Avenger 2.0 said: Asked for heatsink and cooling fan integrated into smallrig cage 🤣 However seeing the overheating test Tony did on Youtube, it looks like the (plastic) shell really isolates the inside heat from the outside. Not sure any fan or heatsink at the outside will even do any difference. looks like is not going to work, the only solution most probably will be an external recording, so get ready for the crappy micro-hdmi nightmare. Link to comment Share on other sites More sharing options...
ntblowz Posted July 24, 2020 Share Posted July 24, 2020 I guess the weather sealing is too good on their camera 🤣 Link to comment Share on other sites More sharing options...
Video Hummus Posted July 25, 2020 Share Posted July 25, 2020 I told them to remove the micro HDMI, because its worthless anyhow, and use the small port to install a tiny exhaust fan, Link to comment Share on other sites More sharing options...
