BenEricson Posted August 4, 2020 Share Posted August 4, 2020 On 8/4/2020 at 11:25 AM, zerocool22 said: Yeah did kinda like this footage, nothing mind blowing but looks like stup up from mirrorless and dslr's type camera's. And I did not like the first footage that was released of the komodo, the dynamic range looked kinda low at the first video's, but just also saw that comparision video with the pocket 6K and it has similar DR to the pocket 6K, highlight rolloff is nicer though so it might have a stop over the pocket 6K. Expand Yeah, this looks closer to the Original BMPCC than the 6k. The colors and highlights are really smooth and nice. Black Magic really misses out on a huge market by not selling accessories like RED does. That handle is awesome. Link to comment Share on other sites More sharing options...
Coiii Posted August 4, 2020 Share Posted August 4, 2020 Link to comment Share on other sites More sharing options...
Super8 Posted August 4, 2020 Author Share Posted August 4, 2020 I don't like what the Aivascope Anamorphic adapter does to this footage. icarrere and zerocool22 2 Link to comment Share on other sites More sharing options...
salim Posted August 4, 2020 Share Posted August 4, 2020 Does the camera have an internal gyro and include the internal gyro data that can be used for post stabilization of the footage like FX9 and Catalyst Browse? Link to comment Share on other sites More sharing options...
Yurolov Posted August 4, 2020 Share Posted August 4, 2020 On 8/4/2020 at 11:25 AM, zerocool22 said: Yeah did kinda like this footage, nothing mind blowing but looks like stup up from mirrorless and dslr's type camera's. And I did not like the first footage that was released of the komodo, the dynamic range looked kinda low at the first video's, but just also saw that comparision video with the pocket 6K and it has similar DR to the pocket 6K, highlight rolloff is nicer though so it might have a stop over the pocket 6K. So this might have my interest again also. Waiting on some more comparison video's and actual commercials shot with it. Expand it is a fake comparison of luts. the roll-off is applied in camera for the red. pure speculation on DR but global shutter has problems for DR so we will see. I am sure the Red will look nicer but it is also x5 more expensive if you add on all the accessories you need. Still we wait to see someone independent doing a proper test though to find out true flaws. Link to comment Share on other sites More sharing options...
kye Posted August 5, 2020 Share Posted August 5, 2020 On 8/4/2020 at 3:25 PM, anonim said: Several month ago I started first to prepare, and than first shooting days of one feature film - and because of working condition (moving quickly, travel abroad to and from Russia including its some wilder area), I decided to base everything on starter kit of 2 Pocket 4k (it was only cine-capable camera that, if something fail, could be buy and replaced quickly everywhere). Expand I've taken a similar approach to my travels in having multiple setups as backups. Considering that although my trips are holidays, they're similar in that we're away from major cities with electronics stores, we have tight schedules that aren't flexible, and I won't want to repeat the same one for lost footage so it's a now-or-never kind of thing. I went through my whole setup looking for single points of failure and eliminating them. I have multiples of every item and can, at a pinch, have anything fail and still continue shooting. The only weakness of the setup was that my backup body wasn't that great. Also, because I had backups of everything I essentially have duplicate setups, and so can film things from multiple angles if I choose to. On 8/4/2020 at 4:10 PM, Super8 said: The Komodo global shutter eliminates the need for IBIS. Expand I disagree. IBIS can reduce and even eliminate hand-shake to create smoother and even locked-off shots, whereas global shutter means that whatever movement is there isn't removed, it's just far less objectionable. Also, IBIS on wide lenses can combine with lens distortion and RS to create wobbling that global shutter does not introduce. So IBIS and GS both have strengths and weaknesses, but aren't equivalent. They're different tools for different jobs. JordanWright, zerocool22, Danyyyel and 1 other 4 Link to comment Share on other sites More sharing options...
Yurolov Posted August 5, 2020 Share Posted August 5, 2020 On 8/5/2020 at 12:01 AM, kye said: I disagree. IBIS can reduce and even eliminate hand-shake to create smoother and even locked-off shots, whereas global shutter means that whatever movement is there isn't removed, it's just far less objectionable. Also, IBIS on wide lenses can combine with lens distortion and RS to create wobbling that global shutter does not introduce. So IBIS and GS both have strengths and weaknesses, but aren't equivalent. They're different tools for different jobs. Expand GS gives you locked off shots if you are steady, but even if there is motion it is much more organic and pleasing - yes the motion is like film. Ibis is unpredictable and you cannot rely on it for sure 100%. I know with my GS camera, the way the image looks when moved craps all over anything with ibis. It is pleasing and smooth whether i pan, walk, etc. kye, BenEricson and icarrere 3 Link to comment Share on other sites More sharing options...
thebrothersthre3 Posted August 5, 2020 Share Posted August 5, 2020 Global shutter is cool but as long as the RS isn't too bad I'd rather have high ISO performance and dynamic range. Link to comment Share on other sites More sharing options...
Super8 Posted August 5, 2020 Author Share Posted August 5, 2020 On 8/4/2020 at 11:54 PM, Yurolov said: it is a fake comparison of luts. the roll-off is applied in camera for the red. pure speculation on DR but global shutter has problems for DR so we will see. I am sure the Red will look nicer but it is also x5 more expensive if you add on all the accessories you need. Still we wait to see someone independent doing a proper test though to find out true flaws. Expand DR is in the clips and perfectly fine. I think he mentions it in the video. What do your eyes see in the video? Global shutter does what it's suppose to do. Clean color and not heavily graded. I'm not sure why people make back handed comments when footage is posted that 99% agree looks good. Color, DR, motion cadence and no rolling shutter. On 8/5/2020 at 1:18 AM, thebrothersthre3 said: Global shutter is cool but as long as the RS isn't too bad I'd rather have high ISO performance and dynamic range. Expand We don't know what ISO performance this has do we? Global shutter is rather new to most of you but you can tell the difference right away. Link to comment Share on other sites More sharing options...
Super8 Posted August 5, 2020 Author Share Posted August 5, 2020 On 8/5/2020 at 1:10 AM, Yurolov said: GS gives you locked off shots if you are steady, but even if there is motion it is much more organic and pleasing - yes the motion is like film. Ibis is unpredictable and you cannot rely on it for sure 100%. I know with my GS camera, the way the image looks when moved craps all over anything with ibis. It is pleasing and smooth whether i pan, walk, etc. Expand What GS camera do you have? Link to comment Share on other sites More sharing options...
MeanRevert Posted August 5, 2020 Share Posted August 5, 2020 That sample video looks great although you can also see how close the Blackmagic came to it. Link to comment Share on other sites More sharing options...
Super8 Posted August 5, 2020 Author Share Posted August 5, 2020 On 8/5/2020 at 1:25 AM, MeanRevert said: That sample video looks great although you can also see how close the Blackmagic came to it. Expand The RED footage looks nothing like Blackmagic footage. Link to comment Share on other sites More sharing options...
thebrothersthre3 Posted August 5, 2020 Share Posted August 5, 2020 On 8/5/2020 at 1:21 AM, Super8 said: We don't know what ISO performance this has do we? Global shutter is rather new to most of you but you can tell the difference right away. Expand I've seen a clip at 12,800 iso it had bad fixed noise pattern. Kinda like what I see from the URSA 4.6K. Need to see more reasonable tests at 3200 and 6400. But its not a good sign. Will need to see some actual dynamic range tests but at $6000 it better give more than say the Pocket 6k at $2000. That's just me though. I use to obsess over rolling shutter but as long as its reasonable I don't really notice unless for very specific shots. If the AF is really good that will be a big deal. Link to comment Share on other sites More sharing options...
Super8 Posted August 5, 2020 Author Share Posted August 5, 2020 On 8/5/2020 at 12:01 AM, kye said: I disagree. IBIS can reduce and even eliminate hand-shake to create smoother and even locked-off shots, whereas global shutter means that whatever movement is there isn't removed, it's just far less objectionable. Also, IBIS on wide lenses can combine with lens distortion and RS to create wobbling that global shutter does not introduce. So IBIS and GS both have strengths and weaknesses, but aren't equivalent. They're different tools for different jobs. Expand GS is not the same as IBIS. Global shutter is a complete scan of the sensor where a rolling shutter is a partial scan of the sensor. Rolling Shutter affects all movement in my opinion. We film and live in a 3D parallax world. I use a Ronin S because IBIS can only do so much. kye 1 Link to comment Share on other sites More sharing options...
Super8 Posted August 5, 2020 Author Share Posted August 5, 2020 On 8/5/2020 at 1:56 AM, thebrothersthre3 said: I've seen a clip at 12,800 iso it had bad fixed noise pattern. Kinda like what I see from the URSA 4.6K. Need to see more reasonable tests at 3200 and 6400. But its not a good sign. Will need to see some actual dynamic range tests but at $6000 it better give more than say the Pocket 6k at $2000. That's just me though. I use to obsess over rolling shutter but as long as its reasonable I don't really notice unless for very specific shots. If the AF is really good that will be a big deal. Expand Here's a low light comparison. Link to comment Share on other sites More sharing options...
thebrothersthre3 Posted August 5, 2020 Share Posted August 5, 2020 Kind of useless in HD. Link to comment Share on other sites More sharing options...
Coiii Posted August 5, 2020 Share Posted August 5, 2020 On 8/5/2020 at 2:14 AM, thebrothersthre3 said: Kind of useless in HD. Expand 2K is mostly for high speed recording. Also, why would you use this camera to shoot 24p HD? This is a 6K Raw cinema camera... Link to comment Share on other sites More sharing options...
Super8 Posted August 5, 2020 Author Share Posted August 5, 2020 On 8/5/2020 at 2:14 AM, thebrothersthre3 said: Kind of useless in HD. Expand Did you really take a screen shot from you tube at HD? I'm not going to get into debating that mirrorless cameras have better low-light capabilities. If you can't see the advantages of this camera then mirrorless is the way to go for you. It might also help to read the comments from the guy that created that video. Link to comment Share on other sites More sharing options...
thebrothersthre3 Posted August 5, 2020 Share Posted August 5, 2020 On 8/5/2020 at 2:26 AM, Super8 said: Did you really take a screen shot from you tube at HD? Expand What are you talking about? The video you linked was posted in 1080p. The compression is so bad you can't tell what the ISO performance is. Again dynamic range and ISO tests haven't really been done to see what kind of sensor this camera has. But yes I'd rather have a Pocket 6k if it gives more dynamic range and better ISO performance or an S1H with prores RAW. On 8/5/2020 at 2:24 AM, Coiii said: 2K is mostly for high speed recording. Also, why would you use this camera to shoot 24p HD? This is a 6K Raw cinema camera... Expand The video of the plane was shot in 6k. Link to comment Share on other sites More sharing options...
Coiii Posted August 5, 2020 Share Posted August 5, 2020 On 8/5/2020 at 2:26 AM, Super8 said: Did you really take a screen shot from you tube at HD? I'm not going to get into debating that mirrorless cameras have better low-light capabilities. If you can't see the advantages of this camera then mirrorless is the way to go for you. It might also help to read the comments from the guy that created that video. Expand I'm on the same boat. I was waiting months for the R5 and Canon fucked up. Then the A7SIII happened and the ONLY thing I was expecting didn't happened (cinetone). I'm done and tired of this game. I just sold my BMPCC4K kit a few days ago and thinking to do the same with my Sony A7III kit and stuff. Just keeping my Canon L glass and save a little more for the Komodo. Link to comment Share on other sites More sharing options...
