Administrators Popular Post Andrew Reid Posted August 11, 2020 Administrators Popular Post Share Posted August 11, 2020 EOSHD testing finds Canon EOS R5 overheating to be fake, with artificial timers deployed to lock out video mode. In this test, we will probe my Canon EOS R5’s actual internal temperature in Celsius, as reported by the firmware. This week CDA-TEK and I are developing an Android app for the Canon EOS R5, which connects to the camera via the Canon API... Please read the rest of the article on the blog carefully before commenting below Emanuel, Robert Collins, tweak and 20 others 16 7 Link to comment Share on other sites More sharing options...
Yurolov Posted August 11, 2020 Share Posted August 11, 2020 Wow. The plot thickens. Great write-up, Andrew. greggreenhaw and foliovision 2 Link to comment Share on other sites More sharing options...
Video Hummus Posted August 11, 2020 Share Posted August 11, 2020 This is incredibly interesting. Would be nice to have a third party try this out and see if the results are replicated. I think this next firmware is going to “fix” that EXIF temperature reporting. Why the fuck did they implement this absurd recovery timer. It’s beyond the realm of defense for being a “conservative” feature to protect the camera from overheating. It’s straight up bullshit, it seems. Great stuff. foliovision 1 Link to comment Share on other sites More sharing options...
hijodeibn Posted August 11, 2020 Share Posted August 11, 2020 F..K canon, I can not accept this kind of scam, if the new firmware do not remove the time limit hack I hope people do not buy this camera. Great work Andrew! andrgl 1 Link to comment Share on other sites More sharing options...
Brett Munoz Posted August 11, 2020 Share Posted August 11, 2020 great job here, if true then fu** Canon! andrgl 1 Link to comment Share on other sites More sharing options...
Administrators Andrew Reid Posted August 11, 2020 Author Administrators Share Posted August 11, 2020 If there is indeed a hardware problem such as the LSI running too hot or certain parts of the chip not turning off when idle, then Canon may have originally developed this kind of temperature monitoring system to keep things in check. But the fake element of it is that the actual temps my camera is reporting are nowhere near problematic and the recovery timer is completely out of whack with both ambient temps and the actual cool down temps of the electronics. So it is likely they found a convenient outlet in the temp management system for a classic Cripple Hammer. I want answers from Canon and I will be seeking them starting tomorrow. Daai, foliovision, noone and 3 others 6 Link to comment Share on other sites More sharing options...
Snowfun Posted August 11, 2020 Share Posted August 11, 2020 How did you test whether the temperature reported by the Canon firmware is an accurate measure of the temperature of whatever component (or part thereof) it purports to measure? I’d be reluctant to rely on that reported temperature when making conclusions. It would be preferable to measure the temperature independently. But that notwithstanding, interesting stuff! Link to comment Share on other sites More sharing options...
Ben i B Posted August 11, 2020 Share Posted August 11, 2020 Wow. I thought they just did a bad job with this camera but if your findings are correct I’m really done with canon. Good there are some other Japanese companies we can rely on. Greetings from Neukölln ;) foliovision 1 Link to comment Share on other sites More sharing options...
Video Hummus Posted August 11, 2020 Share Posted August 11, 2020 2 minutes ago, Snowfun said: How did you test whether the temperature reported by the Canon firmware is an accurate measure of the temperature of whatever component (or part thereof) it purports to measure? I’d be reluctant to rely on that reported temperature when making conclusions. It would be preferable to measure the temperature independently. But that notwithstanding, interesting stuff! Yes I agree. But how? I’m not sure you can take off the back panel and expose the PCB and keep everything working. You would need to take temperature readings from inside. Link to comment Share on other sites More sharing options...
Administrators Andrew Reid Posted August 11, 2020 Author Administrators Share Posted August 11, 2020 The temperature reported by the EXIF data more-or-less corresponds with the Chinese heat gun thermometer tests out there as well and it closely resembles the ambient temp of my room at the moment, I am sweltering in 30 degrees heat! I suppose the easy test would be to cool the camera right down in a freezer, quickly take 1 shot then analyse that EXIF data. It is very unlikely the camera is reporting wrong data in the EXIF. It is very basic to get right, even for Canon. amateurmike, BWV656 and foliovision 3 Link to comment Share on other sites More sharing options...
Ben i B Posted August 11, 2020 Share Posted August 11, 2020 7 minutes ago, Andrew Reid said: If there is indeed a hardware problem such as the LSI running too hot or certain parts of the chip not turning off when idle, then Canon may have originally developed this kind of temperature monitoring system to keep things in check. But the fake element of it is that the actual temps my camera is reporting are nowhere near problematic and the recovery timer is completely out of whack with both ambient temps and the actual cool down temps of the electronics. So it is likely they found a convenient outlet in the temp management system for a classic Cripple Hammer. I want answers from Canon and I will be seeking them starting tomorrow. +1 Link to comment Share on other sites More sharing options...
Super Members BTM_Pix Posted August 12, 2020 Super Members Share Posted August 12, 2020 There is also a relative relationship between the exif data temperature and the inhibitor triggers that are read from the internal temperature status monitor object. When the temperature goes up in the exif files the inhibitions increase in the camera. When the temperature comes down so do the inhibitions. Its like an inverse of a beach holiday to Magaluf. Andrew Reid and Inazuma 1 1 Link to comment Share on other sites More sharing options...
Ben i B Posted August 12, 2020 Share Posted August 12, 2020 Great work Andrew. If your findings are correct it might really be the cripple hammer and that would actually be so canon like. They lost me as a customer 2014 when I bought the the a7s and sold the 5d mk 2 and mk3. I thought Japanese companies have higher standards then this. Maybe somebody will do some harakiri these days... Link to comment Share on other sites More sharing options...
sanveer Posted August 12, 2020 Share Posted August 12, 2020 Interesting and very shady. So, theoretically, it can be hacked to get rid of an artificially controlled/handicapped recording limit. tyger11 1 Link to comment Share on other sites More sharing options...
newfoundmass Posted August 12, 2020 Share Posted August 12, 2020 Imagine that Canon boardroom meeting. "Let's create an 8K beast with little RS, RAW video, IBIS, our best auto focus ever... And then cripple it and use overheating to blame it!" "You're a fucking genius, man. LET'S DO IT!" foliovision, BWV656 and Lux Shots 2 1 Link to comment Share on other sites More sharing options...
newfoundmass Posted August 12, 2020 Share Posted August 12, 2020 Honestly, whether it's incompetence or intentional, the R5 should be reason enough for people to cease supporting this company until they get their shit together. There are companies that value their customers. Reward them instead. buggz, foliovision and Lux Shots 3 Link to comment Share on other sites More sharing options...
Administrators Andrew Reid Posted August 12, 2020 Author Administrators Share Posted August 12, 2020 Just now, newfoundmass said: There are companies that value their customers. Reward them instead. Absolutely. Sigma and Panasonic are my top picks Daai, ntblowz, greggreenhaw and 2 others 5 Link to comment Share on other sites More sharing options...
noone Posted August 12, 2020 Share Posted August 12, 2020 The thing is, if they DO fix this and own up it will be a fantastic camera and many many people will instantly forgive them. mechanicalEYE and Emanuel 2 Link to comment Share on other sites More sharing options...
BWV656 Posted August 12, 2020 Share Posted August 12, 2020 Just now, noone said: The thing is, if they DO fix this and own up it will be a fantastic camera and many many people will instantly forgive them. Yes. I agree. But let's be real. We are dealing with Canon here. I am 99.9999999% sure that will never happen. Lux Shots and foliovision 2 Link to comment Share on other sites More sharing options...
Emanuel Posted August 12, 2020 Share Posted August 12, 2020 Andrew's point is still valid though : ) Thanks you two @Andrew Reid @BTM_Pix for your guts and service to filmmaking, keep going your focus and hard work :- ) theraywong, mechanicalEYE, noone and 3 others 6 Link to comment Share on other sites More sharing options...
