HockeyFan12 Posted August 15, 2020 Share Posted August 15, 2020 Assuming the camera has the paid upgrade. Please say yes? (Unless the answer is no.) PannySVHS 1 Link to comment Share on other sites More sharing options...
pryde Posted August 15, 2020 Share Posted August 15, 2020 The answer is yes. With Vlog upgrade and a recent firmware. They added it at some point with a firmware update. HockeyFan12 and PannySVHS 2 Link to comment Share on other sites More sharing options...
HockeyFan12 Posted August 15, 2020 Author Share Posted August 15, 2020 Thanks, do you know if rather than buying the DMW-XLR1 I can just send audio from my MixPre3 and it will still be decent quality (48kHz/16-bit PCM I guess is fine) and I can lock the levels to match the MixPre3, it won't use auto levels? Link to comment Share on other sites More sharing options...
newfoundmass Posted August 15, 2020 Share Posted August 15, 2020 25 minutes ago, HockeyFan12 said: Thanks, do you know if rather than buying the DMW-XLR1 I can just send audio from my MixPre3 and it will still be decent quality (48kHz/16-bit PCM I guess is fine) and I can lock the levels to match the MixPre3, it won't use auto levels? That should work well, yeah. You might even get better results than with the XLR1. I use the XLR1 as much for convenience than anything. HockeyFan12 1 Link to comment Share on other sites More sharing options...
HockeyFan12 Posted August 15, 2020 Author Share Posted August 15, 2020 1 hour ago, newfoundmass said: That should work well, yeah. You might even get better results than with the XLR1. I use the XLR1 as much for convenience than anything. Oh, I'd rather have the XLR1 for the convenience. But I already own a MixPre3. I suppose I can also record to both and sync in post. I hate doing additional work, but it's not a lot. Link to comment Share on other sites More sharing options...
newfoundmass Posted August 15, 2020 Share Posted August 15, 2020 3 minutes ago, HockeyFan12 said: Oh, I'd rather have the XLR1 for the convenience. But I already own a MixPre3. I suppose I can also record to both and sync in post. I hate doing additional work, but it's not a lot. You'll get excellent results with the MixPre3, I wouldn't bother with the XLR1 unless you need a real stripped down set up. HockeyFan12 1 Link to comment Share on other sites More sharing options...
HockeyFan12 Posted August 17, 2020 Author Share Posted August 17, 2020 Can IBIS be enabled in "6k" photo mode? If only they had a 24p photo mode... Link to comment Share on other sites More sharing options...
pryde Posted August 17, 2020 Share Posted August 17, 2020 46 minutes ago, HockeyFan12 said: Can IBIS be enabled in "6k" photo mode? If only they had a 24p photo mode... yup, IBIS works in photos modes and video modes alike HockeyFan12 1 Link to comment Share on other sites More sharing options...
HockeyFan12 Posted August 17, 2020 Author Share Posted August 17, 2020 Thanks... but I am assuming no way to shoot photo mode in 24p? That would just be too cool. Link to comment Share on other sites More sharing options...
pryde Posted August 17, 2020 Share Posted August 17, 2020 Nope, it’s 30p only. But shoot 1/50th and drop it on a 24fps timeline and you won’t really be able to tell much of a difference. To me, the final product doesn’t look like 30p footage. HockeyFan12 1 Link to comment Share on other sites More sharing options...
ade towell Posted August 17, 2020 Share Posted August 17, 2020 On 8/16/2020 at 12:34 AM, HockeyFan12 said: Oh, I'd rather have the XLR1 for the convenience. But I already own a MixPre3. I suppose I can also record to both and sync in post. I hate doing additional work, but it's not a lot. I use the Mix pre-d with XT3 and did the same with the GH5, found it was best to set the audio level to manual lowest setting on the camera and let the Sound Device lovely pre amps do all the work. Got decent quality audio, the Panasonic was a little cleaner than the Fuji so hopefully the S1 is similar Link to comment Share on other sites More sharing options...
Parker Posted August 17, 2020 Share Posted August 17, 2020 I have always meant to experiment with this mode for a shoot but never have, it uses the full 3:2 aspect ratio of the sensor, correct? So it'd probably have to be cropped for video regardless Link to comment Share on other sites More sharing options...
HockeyFan12 Posted August 17, 2020 Author Share Posted August 17, 2020 Yeah, it looks good: Another question: I'm assuming this 5K is pixel/pixel. It just makes sense given the FOV. The "video" pixel/pixel mode is like 1080p or something... is the APS-C UHD mode also pixel/pixel? PannySVHS 1 Link to comment Share on other sites More sharing options...
billdoubleu Posted August 18, 2020 Share Posted August 18, 2020 Something feels odd about this video. Something with the shutter speed or stabilization, maybe? It's such a tease for Panasonic, with the 6k mode, to all but tell you that the camera will record 6k perfectly fine. Link to comment Share on other sites More sharing options...
HockeyFan12 Posted August 18, 2020 Author Share Posted August 18, 2020 39 minutes ago, billdoubleu said: Something feels odd about this video. Something with the shutter speed or stabilization, maybe? It's such a tease for Panasonic, with the 6k mode, to all but tell you that the camera will record 6k perfectly fine. It's in 30p for one thing but it also feels like there's a bit of skew or IBIS wobble with it, too. Nice image, though. PannySVHS 1 Link to comment Share on other sites More sharing options...
pryde Posted August 19, 2020 Share Posted August 19, 2020 On 8/17/2020 at 9:19 AM, Parker said: I have always meant to experiment with this mode for a shoot but never have, it uses the full 3:2 aspect ratio of the sensor, correct? So it'd probably have to be cropped for video regardless It's not an open gate mode and it isn't down sampling, just reading the 5k portion of the sensor so there is a slight crop. maybe 1.1 or something. Not very noticeable compared to normal photo mode but it's there. Link to comment Share on other sites More sharing options...
