Jeremy Clark Posted August 26, 2020 Share Posted August 26, 2020 I'm moving from a camera with internal ND to one without, and need a variable ND for my sigma 18-35mm (or other variable ND solutions). Anyone have any recommendations? Link to comment Share on other sites More sharing options...
Geoff CB Posted August 26, 2020 Share Posted August 26, 2020 I have this one https://www.adorama.com/hykvc77.html. Great image quality with no color cast for me. A bit difficult to get used to at first because you can adjust the circular polarizer on it as well but I haven't found anything with as good image quality as it produces. Link to comment Share on other sites More sharing options...
Jeremy Clark Posted August 26, 2020 Author Share Posted August 26, 2020 52 minutes ago, Geoff CB said: I have this one https://www.adorama.com/hykvc77.html. Great image quality with no color cast for me. A bit difficult to get used to at first because you can adjust the circular polarizer on it as well but I haven't found anything with as good image quality as it produces. Looks like it doesn't come in 72 MM though unfortunately 😞 Link to comment Share on other sites More sharing options...
HockeyFan12 Posted August 27, 2020 Share Posted August 27, 2020 I have this but I got it for half price open box: https://www.amazon.com/gp/product/B07N1B4LNX/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1 It's not bad at all. Slight warm cast but really good otherwise. It might even be the same OEM. You can always use a step up ring fwiw. Link to comment Share on other sites More sharing options...
Geoff CB Posted August 27, 2020 Share Posted August 27, 2020 1 hour ago, Jeremy Clark said: Looks like it doesn't come in 72 MM though unfortunately 😞 I would get a 77mm or 82mm filter anyway and use step up filters. A lot of big modern glass is in those filter sizes. Link to comment Share on other sites More sharing options...
herein2020 Posted August 28, 2020 Share Posted August 28, 2020 On 8/26/2020 at 6:50 PM, Geoff CB said: I have this one https://www.adorama.com/hykvc77.html. Great image quality with no color cast for me. A bit difficult to get used to at first because you can adjust the circular polarizer on it as well but I haven't found anything with as good image quality as it produces. Do you get an x pattern at the stronger end? I have a Tiffen variable ND which is great at the weaker end but it produces a very faint x pattern at the strongest end...what's worse is it is too faint to see in the back screen so I don't even know it's there until I start editing. Link to comment Share on other sites More sharing options...
Geoff CB Posted August 28, 2020 Share Posted August 28, 2020 22 minutes ago, herein2020 said: Do you get an x pattern at the stronger end? I have a Tiffen variable ND which is great at the weaker end but it produces a very faint x pattern at the strongest end...what's worse is it is too faint to see in the back screen so I don't even know it's there until I start editing. It can result in an X if you push it past max. The filter does not have hard stops on either end of the ND range. Prefer the internal ND of any pro camera, for obvious usability reasons. Link to comment Share on other sites More sharing options...
Jeremy Clark Posted August 28, 2020 Author Share Posted August 28, 2020 I ended up getting this one. Had great reviews, especially on keeping images sharp https://www.adorama.com/slr52vndm2.html Link to comment Share on other sites More sharing options...
hyalinejim Posted August 29, 2020 Share Posted August 29, 2020 Yes I have an 82mm SLR Magic that I've used for years. I've never noticed softening or X patterns. There's a slight blue cast that increases as you darken, but it's not objectionable and easy to correct. Link to comment Share on other sites More sharing options...
Jeremy Clark Posted August 29, 2020 Author Share Posted August 29, 2020 3 hours ago, hyalinejim said: Yes I have an 82mm SLR Magic that I've used for years. I've never noticed softening or X patterns. There's a slight blue cast that increases as you darken, but it's not objectionable and easy to correct. Thats funny, the reviews I read said the same, but a slight warm cast (on the MkII 77mm) Link to comment Share on other sites More sharing options...
hyalinejim Posted August 29, 2020 Share Posted August 29, 2020 You're right! It is slightly warmer and greener Link to comment Share on other sites More sharing options...
