Canon M6 Mark II 120fps footage
kardo
I think that this ffmpeg command will create a new file that runs all the frames at 120fps without transcoding:
       ffmpeg -r 120 -i original30fps_file.MOV 120fpsoutput_file.mov
If it doesn't transcode, it should make the 120fps copy  quickly.  Also, it would be easy to make a script based on this command that would batch convert a bunch of files.
Of course, you could always convert the frames to run at 120fps in an NLE.
  • 2 weeks later...
  • 4 weeks later...
